Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
My i9++ will not connect to at&t network
When i go to network setup it has cingulur but dont know how to set it up i did get it to work for about five min by doing a network search got some text mes but it went away and i cant get it back
Http://www.gsmfans.com.br/index.php?topic=42296.0
Posted on Mar 04, 2010
    Problem Solver:
  • 5 Answers
First of all reset ur mobile by restore factory code
if problem is not solved then u use software isndtallation from ur vendour
Posted on Jul 16, 2009
Hey i have a Sciphone I9+++++ can't remeber how many pluses but none the less i need to set up the MSS and GPRS setting but i dont know the telstra codes for it please help its quite annoying
Join this forum www.i9forum.co.uk it will give you the settings for telstra mms & gprs it is to long to post here, this is where I got mine from and I have the i9 3gs.
Mar 28, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Idont know how too setup this router
is this a hub or a router??...
if it is a hub you dont need to set it up....but if this is a router you need a driver..but remember some router usually dont have driver if they dont have wi-fi....
just connect your pc and connection to it and uit runs automatically...
rate me..
Feb 06, 2010 | Acer ALH 508D (91.AB849.001) Networking...
I dont know how to setup a wireless printer to my laptop. I have a wireless router and an ethernet cable plugged in, but how do I set it on my computer wirelessly?
Well what you do is, First, install the correct driver for your Printer on the one chosen to be the, "Master" PC, then, connect the Printer to that PC via the USB cable. Then after it is installed & shows up,Go to the setup & in the printers Properties, ensure you set the printer for "Sharing" & Take note of where it "Is" & it's "Name" & "Path". Also ALL your PC's MUST have an INDIVIDUAL NAME and be connected to the SAME "Workgroup". Then from each "Client" you must Install a Printer too. Now on Client, go to, Install a Printer, & run it, when it asks what sort? You identify "Networked Printer" and "Browse" for it. When you find it, simply connect to it and follow any instructions. If you can't find it, enter the name of master pc & printers name... (from the Master install). When you connect follow any instructions Now you are ready to print..
When you look for the printer it will look like this....\\Nameofyourpc\PrinterNamehere
So basically, you have setup a network, with the PC's & a Printer... You have one Master that the Printer is connected to, & all "Others" connect, to the Printer, Through, the Master PC, subsequently it must be ON for it all to function.
There is another way, and that requires a printer with an Ethernet connector, this then, can be simply plugged into a router port & it will show up as a network share, that can be used by anyone else on the network., As such there is no master and no need to have any other PC's powered up for it all to work.
Feb 02, 2010 | HP PSC 1410v All-in-One Printer
I9 wap/gprs & mms settings for O2
You need to set it up with the right info. from your wireless service carrier.
Sep 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Annoying clicking sound with my new cect i9 3g
turn off the lock feature for the screen settings/security setup/autolock keypad. seems to have worked for mine but bummer not being able to lock keypad.
Jul 27, 2009 | Dual Electronics CECT P168 Cellular Phone
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
How to download to i9 phone
connect your phone to a laptop or pc using the usb cable...the phone will then show threee options....choose mass storage. this will then setup the phone so that you can see the memory avaiable on the phone under mycomputer. there will be two drives associated with the phone...the internal memory and the memory card. when you browse the drives you will see various folders...copy the media to the related folders.....hope this helps
Jan 07, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 cellphone china iphone clone
At&t WAP Setup
***First Step***
1.Main menu --> Select Services
2.Select Data Account --> Select GPRS
3.Select the first entry
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to WAP@CINGULARGPRS.COM
9.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
For all of you guys out there that need to setup your internet on the cect I9, using att service. drinks.gif 2thumbsup.gif lolup.gif angel.gif
Oct 10, 2008 | Dual Electronics CECT P168 Cellular Phone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
360 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
