Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 Dimension - No Power
Daughter blew a breaker yesterday with her hair dryer. PC is on the same circuit. thru a surge protector. this morning. PC won't power on. No light on PC front button. Changed the PC power cord. Tried a known working outlet. No Fan, no activity onside case execpt single green led on motherboard near power supply. Fan in PS not running. Measured 115 volts at end of cord where it mates to case. How can I tell if the Power Supply is shot? Are there any fuses or things to reset inside the Power Supply? The Dell # on the PS is W8185.
Thanks in advance for any guidence.
Eddie
  • 1 more comment
  • EdfromCT Nov 19, 2007
    Spent an hour on the phone with Dell and they are sending out a tech with a new power supply and motherboard ( just in case ).
    Thanks for your help.
    Eddie
  • rick416 Jan 23, 2008
    EDfromCT's, what fixed your problem? I currently have the same issue and am about to order a PSU
  • Rob Little Apr 24, 2008
    EdfromCT has described exactly the problem I'm having with a friend's Dell Deminsion. I vary from the problem only by virtue of having already tried putting in a known good power supply and it still won't power on. The power supply fan is not running and all I get is the little green light on the motherboard. I don't see any burn marks or anything other signs of electrical damage on the motherboard. My friend had his machine plugged straight into the wall without surge protection and he noticed it not working after a lightning storm.
    My question is:
    Is there some sort of motherboard reset procedure or is the motherboard shot? Or is there a fuse on the motherboard that may need replacing?
    Problem Solver:
  • 17 Answers
There are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu   http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
Posted on Nov 18, 2007
Dell dimension 3000 won't turn on
No way to teat but to install another PS.
Jul 31, 2012 | Dell Dimension 3000 PC Desktop
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
I have a dell dimension 5100 won't come on after shut down.
I will need some more information? Can you see anything on the screen? Have you tried hitting F8 while the computer is booting to see if you can start it in safe mode. It could be one of many problems. I do not want to just guess.
Jan 07, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dell e310 will not turn on
Check the power cord make shure both ends are not loose. Check the switch on the back of the tower. If the computer is pluged in to a power strip check the surge protector most have lighted switch and a reset button. If no power at the wall outlet check that a wall switch doesn't control it and is on. Check circut breaker Or fuse pannel.
Hope This Helps
Please leave feedback
Nov 16, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My Dell Dimension 5100 will not power up.
Hello sorry for your problem,
push the F6 function key and go into Safe Mode and then remove McAfee from your computer. Go Into the control panel and click on Add/Remove Software, once Mcafee is remove reboot your computer and reinstall it if you choose, but you must go into the advance move and learn how to allow other programs to access the internet. There are other anti-virus software that are not memory hogs. Like AVG
Jan 22, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension power supply / motherboard
you may consider reseating the P1 and P2 cables (from the power supply) connected to the motherboard.
you can go to www.support.dell.com and enter the service tag of your dell system (found at the back of your system) and look for the manual on how to add/remove the parts of the computer.
thanks.
Sep 13, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer wont start and is showing bootmgr missing how can i fix this We had a lightening storm recently. My 5100 was plugged into a surge protector. Every other device connected to the surge protector is...
Its not the surge protector problem.
1. Starting your computer press the F8 function key
2. Select Safe Mode
3. Select the restore point and restore the last updations you had done by selecting the date
4. Wait for a time to get confirmation
5. It will restarts the system.
If the above steps are not worked you need to re-install the OS
Let me know that your problem is solved and rate me as fixya!
Jun 21, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
308 people viewed this question
Alun Cox
