Question about Dell Latitude D620 Notebook
Dell D620 cursor not working- floating all over screen, mouse and touchpad not effective
  • 125 Answers
You will need to reload the drivers with dell laptops there is a order in which you have to install the drivers it is shown on the right side of the drivers download page
Posted on Aug 02, 2009
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Cursor is jumping all over the screen before you can point at what you need - Dell D620 - Windows xp pro
Firstly try a different mouse to find out if the mouse is the issue - If so a new mouse is probably needed (assuming you cleaned the trackball/laser - video instructions can be found below)
If the mouse is not the issue, then enter mouse settings on Windows XP, and try adjusting the sensitivity etc. This can be done by going to Start -> Control Panel -> Mouse and adjusting "Pointer Options"
If this fails, try downloading drivers for the mouse (assuming it is optical).
Mar 02, 2011 | Computers & Internet
The cursor on my Dell Latitude laptop keeps floating to the side of the screen making it impossible to do anything. It floats away while I'm trying to control it. It seems to want to cling to the side of...
They all have this problem, try moving the mouse with the TRACK POINT insted of the touch pad (button over the B key) some times it comes back OK when you play with it a bit, if not than you have to replace the whole keyboard assembly
Jan 04, 2011 | Dell Latitude D620 Notebook
I cant move my cursor to my dell inspiron 1545. the touchpad wont work
Connect a USB mouse.
Then, in Control Panel, access the 'Mouse' panel, and "enable" the touchpad.
Nov 26, 2010 | Dell Inspiron 1545 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
My cursor on my Dell inspiron 1525 laptop is stuck in the middle of my screen the touch pad isn't working either I was wondering how i could fix this
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
Apr 23, 2010 | Dell Inspiron 1525 Notebook
Touchpad mouse not selecting when touched
Here is a link , to your drivers for your laptop, in input devices that is a glide mouse driver must be your touch pad hope this helps click here for page
Dec 02, 2009 | Dell Latitude D620 Notebook
Cursor arbitrarly jumps to wherever it may be sitting on the screen. makes typing very difficult
This is an issue with many laptop users because the touchpad is so sensitive that while typing the cursor can be moved when the hand comes into slight contact with the touchpad. You can go into the properties of the touchpad and try reducing the sensitivity and see if that helps or disable the touchpad in the device manager and use a usb mouse.
Oct 03, 2009 | Dell F3534 Touchpad
Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
Mar 16, 2009 | Dell Inspiron 1525 Notebook
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
Dell Latitude D620 Notebook Logo
793 people viewed this question
Alun Cox
