Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
No water to icemaker.
There is water supply going to the drinking water tap but has stopped going to the icemaker in my whirlpool side by side. It also makes an intermittant knocking noise.
This has happened to me. I was told to check the rubber gasket behind the plastic flap by squeezng it to break any freezing which may occur to prevent the water from going into the ice maker tray. This worled as well as using my blow dryer on medium for about 30 seconds to unfreeze this gasket. Worked both times with no repair bills!
Posted on Jul 21, 2009
  • 245 Answers
Check the solenoid on the back of the fridge where the water line is hooked into it. one solenoid is for water the other is for ice this is usually the problem with the icemaker.
Posted on Jul 16, 2009
The icemaker does not work and the water in the door has stopped. The last time water came out it looked colored. Is there a filter that I am supposed to replace? If so where is it?
some models do have a water filter, which is either located at the bottom outside of the ref. on the kickplate,(grill), or inside the ref. itself on the ceiling. If both water to the ice maker and the drinking water stopped at the same time that is more than likely the problem.
Nov 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker stopped working. There is water to the refrigerator (is water to drink) but does not fill icemaker. Thanks, Gene
I changed the water inlet valve on the fridge. It still doesnt send water to the ice maker, but continues to send water to the door, so what do i do now?
Oct 15, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Our icemaker will not shut the water off. I have
It's most likely the water valve in the rear of the appliance. This is located behind the rear panel to the right hand side. The valve supplies water to the ice maker on one side of the valve and water to the front panel for drinks on the other side. The water valve seems to be failing they are pretty easy to replace and not that costly if you can have a go yourself.
Hope this helps
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not getting water to my icemaker.. water is coming out of the water side(drinking)water is coming into refrigerator from mainwater supply. replaced water triple cylinode valve already, but not getting...
frigidaire has put a diode in the harness @ the water valve sounds like diode is bad . hard to find @supply houses may have to order complete wire harness haundi24
Oct 12, 2009 | Frigidaire FRS26H5AS Side by Side...
In the door ice maker has stopped working. the light controller s
when you look at this icemaker there are 2 sets of strippers 1 stationary the other moves. teh one that moves is normally at 2 o'clock position facing the front cover of icemaker. if these teeth are in anyother position for longer than 10-20 minutes then you most likely have a bad motor module on the icemaker, this is a very easy repair you will need partnumber 8201515 from whirlpool or local appliance supply house. thx peyton
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
ED5LHAXMQ00
GO TO WWW.SERVICEMATTERS.COM WHICH WILL GIVE YOU ASSESS TO ALL WP, AND MAYTAG JOB AIDS
May 30, 2008 | Whirlpool Refrigerators
Whirlpool Icemaker flooding freezer
how much water and did you have to shut off the water supply to stop it
Mar 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
355 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
