Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
I have a TB425cs that won't accelerate. It will
I have a TB425cs that won't accelerate. It will idle just fine and starts easy as can be but if I hit the trigger it dies. It seems to run better with the winter switch closed, but still won't spin fast enough to cut. I have replaced the spark plug, checked the cutting head for binding, cleaned the carbuerator, and removed the muffler to see if it was clogged. Also, I replaced the fuel lines and made sure there weren't any holes in the primer bubble. Any ideas about the cause of this would be greatly appreciated.
  • wrksuks Jul 26, 2009
    ok. i got the problem fixed. I had cleaned the carb and all the jets in it, but one of the screws by the needle valve had jets through it that i missed. when i sprayed out those jets everything was fine. thanks for the help.
  • 155 Answers
Try adjusting the mixture screws out a bit if any otherwise it will need a diaphram kit
Posted on Jul 26, 2009
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
I've got a 1996 jeep grand Cherokee with the 5.2 v8 fuel injected Holley throttle body. My problem is while driving at soft or low acceleration it accelerates fine, but if you hit the throttle hard it
I would check the voltage on the throttle portion sensor with the engine off from idle to wide open throttle.If there are any dead spots, replace the sensor. If the tps checks out, you should check fuel pressure. If you have good fuel pressure, you may want to make sure there isn't a lot of slack in your timing chain. I don't believe you mentioned the mileage of your vehicle. Best of luck.
May 03, 2014 | 1996 Jeep Grand Cherokee
2006 TTR125L Starts and Idles fine, but cuts out when I accelerate.
CARB / FUEL LINES/FILTER /ADJUST IDLE/JET PISTON RINGS WORN TOO MUCH AIR ETC
Jun 14, 2013 | Motorcycles
Car starts but won't idle until I accelerate
has base idle speed and kurb idle speed. allows engine to close throttle opening when shutting down to stop pre-ignition or engine running on
Nov 14, 2012 | 1988 Chevrolet Camaro
Crx will idle won't accelerat
I had the same problem with my 91' crx it would idle and have a low rev i adjusted my tranny cable located below the battery tray and accelerated and shifted fine afterwards
Jul 07, 2012 | 1989 Honda CRX
Harley sportster won't accelerate after warm... Idles fine top end is fine
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Jun 25, 2012 | 2005 Harley Davidson XL 883 Sportster
Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Sep 17, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB425CS trimmer hard to start, won't accelerate
Hi the key is moulded as part of the flywheel on most machines these days which doesent take much to sheer off , By the sounds of it this may well be your problem.
Sep 08, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
624 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
