HP PSC 1209 All-in-One InkJet Printer Logo
Jan Hoffman Posted on Apr 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can hp psc 1209 be fixed when it won't turn on?
I can't turn it on. Is there a part it needs to fix it?
Alzubaidi Firas
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Apr 09, 2016
Alzubaidi Firas
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
7
Helped
21203
Points
101
Check the fuse inside the power cord or the fuse of the power supply
How can it be fixed when it won't turn on? Is there a part it needs to fix it?
http://support.hp.com/us-en/product/HP-PSC-1200-All-in-One-Printer-series/90763/model/427974/document/c01321436/
Windows 7 driver for hp 1209 psc all in one
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=427933
2answers
How do I check the ink levels in my HP PSC 1209 printer?
If you used the CD to load the drivers for your printer, in the lower right corner of your monitor you should see some small icons. One is the HP Status Indicator icon. When you touch the icons, they pop a little title box that tells you what it is.
Once you find your status indicator, double click on it. A control panel of sorts should pop up and ink functions should be there.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
Is my hp 1209 compatible with window 7
Yes!!! This is definately compatible, even Microsoft has drivers on their website for this printer. If you are upgrading to windows 7, then i give the go ahead, it is worth it!!!
Hope that helps.
Cannot install the driver in Windows 7 for an HP PSC 1209 printer. Works fine with XP.
Go to hp.com and see if there is a driver for Win 7 and your printer. Vista might work. Otherwise you are SOL
I have a new Dell computer, and I have a HP 1209 printer. I hooked it up and it shows it has the main printer but it won't print anything. Do I need to shut it down and bring it back up.
you need to unplug it from the computer, insert the cd that came with it in the computer and install the software and drivers, only plugging in the printer to the computer when the software installation prompts you to. Then follow the instructions onscreen.
Regards...
My hp printer psc 1209 suddenly stopped working. No power on lights. Nothing at all. What is the first thing to check. Pls advise. thank you.
That the plugs are all attached, to the computer, the wall etc [has the cat/dog walked passed and pulled the plug out.?]
Does another item work in the wall plug.
Have you reloaded the software.?
My hp psc 1209 all-in-one will not scan, i need help please
If the problem is that the Director software window does not open, see HP's fix:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00802504&lc=en&dlc=en&cc=us&product=427933
It's apparently a problem after Internet Explorer version 7 is installed.
If your problem is that the Scan button no longer works under MS-Vista, see HP's fix at:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&softwareitem=oj-46104-1&os=228&product=427933&lang=en
Hopefully this will help you out!
HP PSC 1209 All in one InkJet
Hi, just click the link & the manual will start to load.
Don't forget to save the file to your PC.
HP PSC 1210 Series Printer.
http://h10032.www1.hp.com/ctg/Manual/bpu70201.pdf
Good Luck & Kind Regards.
& please vote.
k24674
Grand Canyon Tech
Grand Canyon Tech
