Question about Dyson Ball DC24 Bagless Upright Vacuum
Same here - but think the switch is the problem
My button for beater brush also only works intermitently. Also, the button to power off sometimes does not work.
  • 97 Answers
Power is the switch and the agitatior is the belt.
Posted on Jul 20, 2009
Beater bar isnt working I have replaced motor on dyson dc18
Be sure you are getting power to the brush bar motor. Power comes from the main switch to the brush bar switch, then to the micro switch that activates when the handle is reclined, then to the brush bar motor. Any openings in the circuit will cause the brush bar motor to not work.
Jan 23, 2017 | Dyson Vacuums
I was vacuuming with my DC28 Animal and all fo a sudden the beater bar stopped working and NONE of the floor mode buttons work.. no lights or anyhting. I checked for obstructions per the Dyson manua
Check the wire connection that feeds that section. to make sure it is being supplied power. Since motor is also not working it has to be something they all have in common -POWER!
Sep 06, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
Beater bar turns but not when the vacuum head is against the floor.
1) test the power cord for open
2) see inside fuse or reset button and reset if there are
3) power switch defective or some wire loose fix it
4) connector inside loose tight
5) c.breaker from your home tripped, reset.
6) if not work, the motor is defective, brush, winding repair.
God bless you
Jun 21, 2012 | Dyson DC25 Vacuum
The brushes stop rotating on rugs after a few seconds then button has to be pressed to start rotating again but keeps cutting out
Not sure this is your foolproof solution to the problem, but you might give it a try to see if it solves your problem.
When the beater brush starts to bind up due to debris it retards the action of the cleaner, sometimes to the point of the belt breaking.
Remove the beater brush as if you were going to change the belt. Remove all debris and clean as best you can. Pay attention to the end pieces on each end of the beater brush. They will can clogged to the point to stopping the brush from rotating. Add some WD40 to the clips at the end of the beater brush and work in by twisting the clips while holding the beater brush. Once it seems to be free, reassemble and be sure the belt is on properly, you might want to consider replacing the belt.
If you find this solution to be of help I would appreciate a Thumbs Up. Good luck and be well. Paul
Oct 06, 2010 | Dyson Vacuums
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc17 amimal's main turbine head is not working, is there a reset button or any other solution? I don't think it is the belt!
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
May 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Brush roll won't turn
I think the belt has probably broken. These are easy to replace and you can access it by taking of the bottom section around the brush. If you do this you will see instantly if the belt is brokenm or not. Most electrical shops sell these belts-otherwise ebay do them
Jun 13, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
482 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
