SOURCE: Hotpoint EG54P ignition sparking by itself
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
SOURCE: oven doesn't work unless a burner is on.
The Control Board in back of the knobs is defective. Easy fix, about $80.00
SOURCE: Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
SOURCE: I have a Maytag CRE7500ACW. Last couple days the
Hi droshe88,
If burners are not heating up kindly test the following:
Test Oven Element. The oven heating elements are large resistor wires with enough resistance to generate significant heat. There are two heating elements in each oven: a bake element and a broil element. The bake element is found on the bottom of the oven, while the broil element is found on the roof of the oven. On some models, the bake and broil elements will work simultaneously to preheat the oven cavity.
To test bake element
To access the bake element, open the oven door, remove the oven racks and then remove the screws that hold the element in place.
There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning, reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
Visually check the entire element for signs of burn.
Test the element for continuity. Using the ohmmeter, set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms.
If there are any signs of element burning, or if there is no continuity, replace the element.
To test for a grounded bake element, place one probe on the element outer surface and the other on the element terminal. If continuity exists, the element has shorted and should be replaced. Remember to test both terminals.
To test the broiling element, is the same process as the above. To access the broil element located on the roof of the oven cavity, first open the oven and remove the oven racks. Remove the screws that secure the element to the oven, remove the holding brackets from the element and slide the element forward.
With the display issue replacing the display control board will resolve the problem.
Here's the link where you can find the diagrams for your machine. As well as if you need parts you can also order from them.
Hope this helps.
Thank you for using FixYa.
