Question about Mitsubishi WS-65819 TV
Can't aline the vertical red and blue on the left
Can't aline the vertical red and blue on the left and right side in the advanced convergence. Creates double image in the left and right side when viewing tv
  • 668 Answers
The Convergence circuit has failed. It is recommended that a professional do the job.
The Convergence IC's need to be replaced.
It will be a STK393-110 or a pair of STK392-570's.
Hope this helps,
skyassoc
Posted on Jul 17, 2009
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
    Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
    Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
    Cannot adjust horizontal blue convergence on WS 55857
    You still have bad grounds on the ICs. Or maybe the solder has fused another pin. If not bad grounds on the ICs you have missed them elsewhere...Really concentrate and look for these bad grounds and check your caps with a cap check. And power resistors too!!!!!
    Sep 16, 2009 | Mitsubishi WS-55857 55" Rear Projection...
    I have a Panasonic PT-53WX54J that will not Converge
    you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
    Aug 23, 2009 | Panasonic Televison & Video
    Covergence out of alignment on 1/4 Vertical left side of screen
    You need to manually adjust the alignment:
    On remote, press Menu to get to the main menu
    Then arrow down to "ADVANCED FEATURES"
    Then press "enter"
    Then Arrow down to "CONVERGENCE" and press "enter"
    "Red Convergence" should be highlighted
    Press "enter"
    You now have Green, Red, and Blue overlapping crosses.
    If Red is out of whack, use arrows to align
    To toggle to blue (and back to red), press "VIDEO"
    Then align blue cross
    Once the crosses look aligned, and nice and white, press "AUDIO"
    This will bring up the Advanced Convergence screen
    This is a grid of the same overlapping colors
    You have control over the Red and Blue
    If Green is very out of whack, you'll need a repairman…
    While the "target" is flashing, you can move it around the screen with the arrows
    Place it over an intersection to adjust, then press "enter"
    Now the "target" is steady (not flashing), and you can use the arrows move your color
    When it's aligned, press "enter" again
    Now "target is flashing, and you can go to the next square.
    You cannot adjust every intersection.
    Some areas need to be adjusted via the adjacent intersection
    When you're happy with color you're working on,
    Press "video" while target is flashing to change to the other color
    Repeat the above (blue is much harder to see and adjust for me…)
    When you're happy with the entire grid, start hitting "Menu"
    Each press brings you back out one menu level, until you are out of them
    Once you're used to the process, it should take no more than a minute or two.
    Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
    Pioneer SD-641HD5 red convergence - not chip problem!
    Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
    Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
    Red horizonal convergence tilts instead of adjusting evenly.
    For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
    the convrgence board.
    Good luck
    Dals123
    Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
    Akai pt5598hdix convergence problem.
    go to the following link and click the contact link on the lower left side and tell them your model they will email you with the correct convergence ICs that you need for your model. they also provide free installation instructions with pictures and free tech support when you order the replacement ICs.
    http://servicemanuals.vstore.ca/
    Apr 22, 2008 | Akai PT5598HD 55" Rear Projection...
    Red convergence will not adjust.
    Replace STK393-570 convergence amp IC = common repair
    for qualified Mits tech............................T.
    Nov 09, 2007 | Mitsubishi WT-42413 42" Rear Projection...
    Mitsubishi WS-65819 TV Logo
    120 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
