To help you understand for deleting bookmarks in your Mac computer, please follow the steps mentioned below:
-Open Safari browser.
-Tap on the open book icon.
-Locate the bookmark you no longer want, and (right click) control + click on the bookmark, and select 'delete'.
To help you understand and delete the bookmarks from your android tablet, make sure you really want to delete it, and that you've chosen the right bookmark because this would delete the bookmark completely.
Please follow the steps given below:
- Launch your Android web browser.
- Tap the 'Bookmarks' icon in the top right hand corner.
- Tap and 'Hold the bookmark' you want to remove, until a window pops up.
- Select the 'Delete bookmark' option, then tap OK.
I tried this first on a new unnamed folder to make sure it worked first. I am using a Mac, and hope this will help you. I went to my "Bookmarks" - "Show All Bookmarks" and simply clicked on the folder I wanted to delete, went to "Edit" and simply hit the delete key. If there are only individual bookmarks in a particular folder, open the folder, click on the bookmark you want to delete, then follow the same steps above. You can delete each bookmark or an entire folder. Hope this helps.
Are you trying to remove the button for bookmarking or a bookmark itself?
The button is a permanent fixture to most browsers, however to delete a bookmark you need to use the "show all bookmarks" button or find the bookmarks manager in the menu at the top, which should have a bookmarks section, once there find the bookmark your looking for and simply right click and hit delete.
Open Safari by clicking on the Safari icon in your Application Dock. If you do not have Safari in your dock, click the Finder icon in your dock to open the Finder window. Click on the Applications icon in the far left column of you Finder window, and then double-click the Safari icon.
Identify the bookmarks you would like to keep and the ones you would like to delete. Safari has a bookmarks bar and a bookmarks pull-down tab. Delete bookmarks that are saved on your bookmark bar by hovering the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
Delete bookmarks in the pull-down menu by clicking the Bookmark tab at the top of your screen. Select the first option called, "Show all bookmarks." Select the "Bookmarks Menu" option in the left hand column of the window that pops up. Hover the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
foloow this instruction and fix it. God bless you
Instructions
1.
Internet Explorer 7 and 8
o1
Open Internet Explorer.
o2
Click "Favorites," and then click the arrow next
to "Add to Favorites" if you are using IE 8. Click "Add to
Favorites" if you are using IE 7.
o
Click "Organize Favorites."
o4
Select the bookmark you want to delete, and then click
"Delete" and "Yes."
o5
Note that you can also right-click bookmarks in the
Favorites menu and click "Delete."
2.
Firefox
o6
Open Firefox, and click "Bookmarks" on the top
menu bar.
o7
Click "Organize Bookmarks."
o8
Select "Bookmarks Menu." Select the folder of
bookmarks you want to work with on the left side of the window, and click the
bookmark you want to delete in the right pane.
o9
Click "Organize" at the top of the window, and
choose "Delete." You can hold the "CTRL" button on your
keyboard as you click if you would like to select more than one bookmark to
delete.
o10
Note that you can also right-click items in the bookmark
menu and click "Delete" to remove them.
Open your browser and enter the bookmarks menu. Long press the bookmark you want to delete and select "delete/remove bookmark". You may need to scroll down to see this option.
On firefox u would just click Bookmarks, then "Organize Bookmarks".
When the pop up window shows up select the one you want to delete-
(Control+click to select) and say "delete" or
on internet explorer u would just click bookimarks with the arrow going
down and click manage bookmarks and next to the bookmarks..it sez edit
or remove and u click remove...if u wanna delete all then go to the
side of the page under bookmarks and click delete all
