Question about Whirlpool Washing Machines
The washer stops right after agitating - Whirlpool Washing Machines
  • Whirlpool Master
  • 3,361 Answers
Most likely a bad lid switch. If you manually advance the timer and it works, it is a bad timer. If it still does not work, a bad lid switch.
Posted on Jul 16, 2009
Drum turn left side easy by but right side hard
A Quick and Easy Fix for Whirlpool Washer Brake Lockup
www.davesrepair.com/DIYhelp/DIYddbrakelube.htm
The symptom of what I call 'spin brake lockup' is the washer's basket stopping ... of this article for help) and you'll see the chrome clutch drum, right above the transmission. ... It would be very hard to put grease on the clutch linings inside the lower clutch drum, but I mention ... Please click the "donate" button on the left side of
Washer Agitator/spinner Turns One Way, But Not The Other ...
www.diychatroom.com/.../washer-agitator-spinner-turns-one-way-but-no...
Jan 9, 2009 - 6 posts - ‎2 authors
It agitates just fine, but when the direction switches to spin the drum, it almost feels.... That will make it easier to remove the belts and turn the drive pulley. ... find that the drive pulley won't turn anymore, or will be very hard to turn. ... on the left side or the hose going to the air pressure switch on the right side.
Nov 15, 2015 | LG Washing Machines
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series top load washer that is about 20-25 years old and works very well. I think that an object has slid under the big thing in the middle of the...
if it is like the other you have to remove the top cover of the agitator cap with a small flat head screwdriver, then using a 7/16" socket and ratchet with an extension remove the bolt(right hand thread) and pull up the agitator.
good luck to you.
Feb 08, 2011 | Kenmore Washing Machines
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
I have a top loader whirlpool ultimate care 2 it keeps stopping once filled with water it stops have had timer replaced
May 27, 2010 | Whirlpool Washing Machines
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
