SOURCE: Which cylinders would be PO352:Ignition coil
6 Cylinder Applications
A
A
26
P0351
B
B
52
P0352
C
C
78
P0353
5
A
A
26
P0351
B
B
52
P0352
6
C
C
78
P0353
First column is of course cylinder no., 2nd is the igntion coil, 3rd is the coil driver,4th is the PCM pin number,and last the related code.
SOURCE: Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
SOURCE: need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
SOURCE: Need diagram for ignition coils
Same as Ford Escape.
P0351 - Ignition Coil A - Primary/Secondary Circuit
Cylinder #1, Pin 26 at the PCM, computer.
I would replace the coil on the plug (COP) for that cylinder and see if its' ok. If not, then it is possible that the bad coil took out the driver in the PCM. The test at Pin 26 to see if the light blinks, must be done with the correct tester or it will damage the PCM.
Hope it's the coil.
report results.
4 cylinder or 6 cylinder engine?
