Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore top load portable washer leaking, model 110.42722200
Leaks from the bottom. Started a few months ago and has gotten increasingly worse. Washer about 5 years old. WIll try suggested solution.
  • Kenmore Master
  • 3,361 Answers
Replace the water pump. The seal is leaking.
Posted on Jul 16, 2009
My kenmore HD 90 washer model 110 82993800 leaks with a larger load and seemingly only on rinse. Water is on floor and has progressively gotten worse. when I moved the machine there was a dark powder on...
This washing machine is nearly 20 years old. The newer ones save you a lot in using less water per load and you would be better off financially in the long run.
My new front loader saves me $40.00 a month because it is so conservative with water.
Jun 08, 2017 | Washing Machines
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Mar 09, 2009 | LG WM-2277HW Front Load Washer
Water leaks from bottom
Sounds like your drain hose isn't connected properly to the machine. Look for the base of the hose and see if there's something you can do.
Nov 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 80 series
suspect sand/rust has gotten past screens inside water valve or screens are missing allowing residue to get into valve ..replace valve ..clean screens as needed in future but be sure to reinstall
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
945 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
