Question about Garden
The slip clutch on my McCulloch EM14ES electric chainsaw slips.
The slip clutch on my electric chainsaw slips. Where can I get a replacement slip clutch?
  • dontbother10
    dontbother10 May 11, 2010
    I'm not able to cross the numbers you provided to any electric Macs. If you can provide some additional detail we may be able to help. Is she European?
  • 6 Answers
SOURCE: golf mk4 slipping clutch
IF YOU GO ON EBAY DISCOUNTCARPARTS4U THEY DO A 4 PIECE CONVERTION KIT FROM DUEL MASS TO NORMAL CLUTCH SAVING YOU MEGA BUCKS .A* EBAYER
Posted on Oct 11, 2008
txkjun
  • 409 Answers
SOURCE: Slipping Clutch
If you have a clutch cable thenyou can adjust it. If it's a hydraulic system you need a new clutch.
Posted on Dec 31, 2008
  • 603 Answers
SOURCE: OLD SEARS ELECTRIC CHAINSAW SPOROCKET SLIPS WILL NOT CUT
The best way I have found is to remove the sparkplug and rotate crank until the cylinder is down about an inch. Jam quiet a bit of shop cloth down in the plug hole then rotate the shaft until the cloth stops upward movement of the cylinder. Now you should be able to get the nut off. You can also remove the nut with a air impact hammer as the impact action will loosen the nut.
Posted on Apr 12, 2009
dontbother10
  • 2220 Answers
SOURCE: how to remove clutch. McCulloch 438 chainsaw.
I think its an outboard clutch, use this as a guide. A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I cannot find an IPL for your saw, it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
Posted on Sep 10, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
How do I replace the chain on my McCulloch Mac 110
Loosen the to bolts on the side cover remove the bar and slip off the chain and put the new one on.
May 09, 2016 | McCulloch Garden
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
Why would the rope slip when you pull it the rope to start my mcculloch chainsaw but it does start
the starting clutch is slipping , this is not to be confused with the chain clutch (other side) reasons a start clutch slips , dirt inside /broken friction surface
May 22, 2014 | McCulloch Garden
Need model number for the chain for a McCOLLOUGH EM14ES chain saw. Thank you.
Any good chainsaw shop will make a chain up for you, most hobby machines run a 3/8 050 low profile chain such as 91s or 91sg, the lenght is denoted by the drive link count, 52 54 56 etc
May 31, 2011 | McCulloch Garden
Chain stops when it touchs log
A gas engined saw has a clutch that can slip if overly oiled internally, but electric saws don't use a clutch. Most however, have a safety disconnect to the drive sprocket that shears or otherwise removes power to the chain while the motor runs. The worst problem can be a broken gear within the gearbox and requires dis-assembly to discover. Many modern saws use plastic gears in place of metal ones and are prone to failure. The fact that the chain turns when not under load would seem to eliminate the gearbox, but don't discount that until proven. Hope this helps!
Jun 23, 2010 | McCulloch 10" Electric Pole / Chain Saw
Clutch has no holding power
Hello Mike;
I think there are burrs on the drive links (binds in bar) see the upper part of this please.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If the clutch still slips post back (below) with a model number and we will look at clutch/clutch drum replacement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 07, 2010 | McCulloch Garden
Mcculloch Pro Mac 700 Chain slips
Make sure the saw is pumping oil to the bar and chain and that the chain turns by hand freely. If ok, is there a sheared or missing key between the clutch center hub and the crankshaft?
Aug 10, 2009 | Garden
Who is the manufacturer
Some of the Ward saws had been made by black and decker and Mculloch ,it's hard to still get parts, your local lawn mower sales shop can compare the clutch and mabe have one
Feb 20, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
603 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
