The seine board on my toshiba tv has gone out and I'm told That I can unplug the board and it will work with cable .
  • tdrofam Jul 16, 2009
    The picture will show up for a second when you first turn it on and then go out ,when I place a dvd in it the sound will play but no picture.I would like to unplug the seine board but I do not know what I'm looking for.I've tried unplugging several white plugs but nothing.
  • tdrofam Jul 17, 2009
    Thanks for the info ,but I've had the tv unplugged for several weeks and after reading the problems and what others had done decided to give it one more chance.If I knew were the seine board was I would try unplugging it. the tv is about 16 month's old and I hate to loose it.Any more suggestions,Thanks Thomas
  • 5,807 Answers
since audio is working it means it is well connected to your TV
for your picture try to relocate,
means to unplug it to the original position
and plug it to other video input
say your DVD player is connected to video 1 move it to video2
and watch if the same problem occurs
for coaxial cable connections:
have the cable disconnected first and power up your unit and see if problem still occurs.
having done that and still not having picture, you might have a circuit board failure inside the unit.
it might not power up well if the fault is repaired and corrected.
possible causes might be:
a) power supply - not having enough to power up the horizontal deflection circuits
a leaky capacitor perhaps
b) horizontal deflection circuits- might have partially shorted flyback, a shorted horizontal output transistor or both
hope this helps, thanks for using Fixya!
Posted on Jul 18, 2009
  • Rommel Cana
    Rommel Cana Jul 27, 2009
    there might be fault on other boards too, try the logic board
  • Rommel Cana
    hi,
    if the unit is still in warranty period, give a ring on the dealer , or visit the manufacturer web site .
    President:
  • 2,187 Answers
Normally these boards do not go out easily. Are you getting the blinking yellow light? I would suggest to leave the TV unplugged at least 4 hours or overnight to be sure to clear out or "reset" the tv.
Posted on Jul 17, 2009
    Top Expert:
  • Televison & ... Master
  • 76,649 Answers
THAT MAY OR MAY NOT BE TRUE, IF THE TUNER WENT OUT THEN YES, IF THE MAIN CIRCUIT BOARD HAS FAILED THEN NO YOU WILL NEED TO EITHER REPLACE THE TV OR REPAIR IT.
Posted on Jul 16, 2009
I have a toshiba 37LX96 that has the yellow blinking light
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name "Toshiba", in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | Toshiba Televison & Video
My Toshiba tv model 32LV67U hdmi connectors are not responding. Other than that the tv works great. Can this be fixed? If so, how and how much will it cost to do so?
I googled the seine board number and it sells for $95. If the TV is fairly new I would write to Toshiba about the problem. I am a bit old school and do not expect certain equipment to fail prematurely. Even if the warranty ran out it is worth telling them how you feel. Maybe you can get a discount on the part or some other compromise on the repair if your communicate effectively with Toshiba. Good luck. ( I think I will check all my HDMI ports now before my the warranty on my TV runs out.)
Nov 30, 2013 | Toshiba 75007221 75007222 PE0361A...
I need to replace my seine board on my toshiba 42hl167 tv and need to know how to do it
What is the sein Board? I'm guessing you mean the signal board since you are also talking about updating the firmware. Signal boards are not too hard to replace on an lcd TV depending on your abilities. You can do a search for a service manual on the internet it will give you detail instructions on how to replace the board.
You can get parts at www.interliquidparts.com
Dec 05, 2011 | Toshiba 42HL167 42 in. LCD Television
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
50HP95 Toshiba Plasma TV No power but blinking power light
I had the same problem with my 50HP95 Toshiba Plasma TV. It would not turn on. I read online that if you unplug a connection on my TV and it turns on, it is a bad Seine board. I could not find this Seine board anywhere online. It was either out of stock or no longer available. The TV is just 5 year old. Why would they discontinue parts for it? Then I saw a video on You Tube where someone unplugged a connection in the back of his TV to fix problem. I decided to try it. I took the back off, unplugged a connection numbered PJ63A and the TV works again. So far so good. I downloaded the Service manual for this TV to find where PJ63A was.
I also called Toshiba Tech Dept. to find out if there was a chance I can cause further damage to my TV. They had no idea.
Mar 27, 2009 | Toshiba 50HP95 50 in. Plasma Television
How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Dec 13, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Plaid Screen
The problem is likely with your seine board or another video board. It will have distorted video/colors and you will see copies of the image in random sizes/places around the screen. If the toshiba menu is distorted it is in later stages of video, if not then earlier. More info will narrow down exacly which board. You can try reseating the LVDS cable, the computer looking one in the middle of the tv. It goes from the video board to the light engine. Unplug the tv and take off the back. The cable is usually white and has a D-type computer like connector with buttons or screws to unlock.
Dec 06, 2008 | Toshiba 50HM66 52" Television
TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
78c6772.jpg I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
Feb 04, 2006 | Toshiba 42HP95 Television
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
