I attempted to update driver for Monitor (LT916) at the direction Uniblue Registry Booter and the screen became fuzzy with low dpi.
  • bburleyone Jul 16, 2009
    I did a system restore before I got the e-mail, but all is working well. This has been a learning experience.
  • 19,396 Answers
The easiest thing to do is a system restore to a date before you installed the new driver update. This will remove the update and should restore things back to normal.
If you are using Windows you find System Restore from Start>Programs>Accessories>System tools>System Restore.
If System restore does not work then you can try reinstalling the monitor as a generic monitor, you can do it from the Hardware Devices list in control panel.
First try doing a System Restore , that will be much easier and faster.
Regards.
Posted on Jul 16, 2009
My monitor is fuzzy in internet
Fuzzy on the internet and everything else or fuzzy just on the internet? check for monitor resolution and see if you have the screen resolution set right. If you have the resolution set too low, the screen can appear more fuzzy if the aspect ratio is not set right.
Jun 04, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Where can i get Uniblue registry booster 2012
Go online and Type: Uniblue registry booster 2012
May 02, 2012 | Computers & Internet
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
Apr 16, 2012 | Samsung R519-53S Notebook
What registry cleaner should one buy to keep all programs running effectivly, update all drivers, stop usless programs from running, etc.
The Best Registry Cleaner Is The Uniblue's Product Registry Booster, The Software Will Scan All Your Registry Files And Find The Errors To Eliminate Them From Your Computer And Makes The Computer Fast.
To Download Go To
http://download.uniblue.com/site/prodpage/rb/registrybooster.exe
Sep 19, 2010 | Computers & Internet
My cumputer is very slow
Reinstall Your operating system.
Aug 31, 2010 | Dell Computers & Internet
Computer does not display full screen
Check your desktop display settings. Sometimes programs change this and uninstalling or going to to another start point doesn't help
May 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Following installation of Norton 2008 all pictures viewed through internet explorer are poor quality and pixilated
Do you use ie6?
IE6 is set up to resize the images based on the Display DPI setting. You can either set the DPI to the default (Normal - 96) or remove IE6's UseHR registry key to deactivate image resizing. Here are the relevant information (from Microsoft Knowledge Base):
Image Scaling in Internet Explorer (hi-res)
How to Activate Image Scaling
Internet Explorer 6 and later automatically adjusts the scale on higher resolution systems when the DPI setting is higher than 96 DPI and the "UseHR" registry value is added to the registry. These are usually done by the manufacturers of higher resolution systems.
_registry() warn.gifWarning!!!: Using the Windows Registry Editor incorrectly can cause serious problems requiring the re-installation of your operating system and possible loss of data. I do not and will not support problems that arise from you editing your own registry. Use the Registry Editor and my directions at your own risk. Be sure that you create a backup of your registry and be very sure that you know how to restore it. If you are not sure how to do both of these things then STOP here!! and read the directions.
Set the DPI
These are the steps for changing the DPI setting on your system.
    Right-click the Windows desktop to display the context menu.
    Click Properties on the context menu to display the Display Properties dialog.
    Click the Settings tab on the Display Properties dialog to display the Settings tab.
    Click the Advanced button on the Settings tab to display the monitor properties dialog.
    Select a DPI setting in the Display frame of the monitor properties dialog to change the DPI setting.
    Restart your system to allow the changes to take effect.
    Add the UseHR Registry Entry
    The UseHR value is added to the Main key under "Internet Explorer" as follows:
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
    Right Click in the right pane and select New>DWORD value and set its data to 00000001
This problem can also be caused by bad video drivers. Update your drivers from the manufacturers site.
Jul 06, 2008 | Computers & Internet
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
