Question about Zanussi FLE1416W Front Load Washer
Drum is stiff to turn
Hello.
The drum is very stiff to turn even after taking the belt off.
Any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
Why my lg washing machine dryer drum turn by hand to right like jam but left turn free
Posted on Nov 15, 2015
    Champion:
  • 249 Answers
Clothes caught between inner and outer Drum, you have to get it out !good luck eire.
Posted on Dec 02, 2007
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
Dec 15, 2011 | Whirlpool Dryers
Maytag washer model PAV2300AWW does not spin the clothes adequately and vibrates Is it the belt or Snubber?
Might just be a belt which is real easy to replace, no tools needed:
Take that belt off there and check the stiffness of the pump.
These will lock up or get stiff without even leaking.
If that pump seems fine check to see if the main drive pulley is properly releasing the tub in the direction of spin. Their are 2 marks on the pulley, the drum should release in between the two points. if not then the thrust bearing kit needs to be replaced.
I have a pictorial of that and a service manual HERE
Jan 30, 2011 | Maytag Washing Machines
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Drum of washing machine stiff and clothes don't dry after spin
poss item of clothing under drum take belt off and see if its free to turn if not remove sump hose or element to find wants jamming the drum.
Sep 14, 2009 | Indesit W 123 Front Load Washer
Drum does not turn
Here are a few things to check. If you don't feel comfortable performing these check, please have a repair person come in and check it.
* Broken belt. Open dryer and see if belt is still wrapped around the drum. Pull on the belt to make sure it's not just hanging there. Inspect belt condition. Do not apply spray adhesive in this case: replace the belt. If belt is broken, look for contributing causes for failure such as worn drum rollers, damaged felt kit, or stiff idler roller.
* Motor burned out. Remove belt from motor pulley and start dryer. If motor runs but is noisy and motor is unable to turn the drum when the drum belt is threaded back on the motor pulley, then replace the motor.
* Thermal fuse is open. Run continuity test.
Hope this helps.
Sep 10, 2009 | Kenmore 63942 Dryer
Dryer heats up but drum doesn't turn.
If the drum is very stiff to turn could be the drum bearings shot which would account for the broken belt, replace belt and it liable to break shortly after again. hover are known for there bad bearings and they cost a small fortune.
check it out have a look and see if there is nothing jaming the drum inside, i am certain your belt has gone and maybe down to the stiff drum making belt break, replace belt but bare in mind it may break again if the drum is too stiff.
choice is yours really. bearing kits cost more than 50 quid in general
Jul 10, 2009 | Hoover Dryers
Drum is stiff
The bearings for the drum have failed and I reccondmend that you either get someone to do it or get yourself another machine.
The bearings can be replaced if your mechanically minded.... however this sort of job is best left to the experts...
Nov 18, 2007 | Zanussi FLE1416W Front Load Washer
Drum is not easy to turn
clothes caught between inner and outer drum .get them out !!!clothes hanger could be used to fish them out Good Luck Eire
Zanussi FLE1416W Front Load Washer Logo
347 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
