You can try this and see if it works for you:
Connect to Wi-Fi networks
Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this
. If your device is running 4.3 or lower, the Settings icon looks like this
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
- Open your device's Settings menu .
- Under "Wireless & networks," touch Wi-Fi.
- Touch the Wi-Fi switch to turn it to the On position.
- You'll see a list of saved and available networks.
- Secured networks display a lock icon and ask for a password to connect.
- Your device will remember networks it connects to and automatically connect to them when in range.
- You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
- Touch a network name from the list of available networks to connect to it.
- Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
- Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
