Question about Refrigerators
Whirlpool heat probe question - PLEASE HELP - URGENT!
Somebody please help! I have a question about the heat probe 819043. I just had a service technician here to put one of those probes in my whirlpool refrigerator. When it goes into the drain hole, I believe it touches a rubber part of the drain hole. My concern was that the probe would melt this rubber, causing unwanted damage. The technician insists that it wouldn't do this. He said the aluminum probe would not get as hot as the heating element. (By the way, he did not use the little piece of tubing that came with the part.) The probe is stuck pretty far into the drain hole. I'm really concerned about it melting things it shouldn't. Can anybody help me with this please???? I would really appreciate it!!!!
  • Refrigerators Master
  • 3,361 Answers
It will be fine. It will only heat to about 65 degrees. Enough to keep the drain hole from freezing but not enough to damage. It is the factory recommended repair. Newer refrigerators come with it already installed. The extra part is used for different model fridges. If yours needed it he would have used it.
Posted on Jul 16, 2009
Why i can't log in my facebook account
i just can log in a few second.....why...??after a few second it will show me this'' http://www.fixya.com/support/t14206087-check6only_facebook_comajax'' and what is this?? can somebody help me settle about this problem please ......i need to use in urgent thank you very much.........
Sep 28, 2012 | facebook.com
Fridge is leaking water from the inside, on the back wall
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
I have ice buildup in the freezer which is leaking into the refrigerator. I have a Whirlpool model ET8CHMXKB05
YOUR DEFROST DRAIN IS CLOGGED IN YOUR FREEZER. UNPLUG UNIT. REMOVE BACK WALL OF FREEZER. REMOVE FREEZER FLOOR SOME DO NOT COME OUT. REMOVE ALL ICE. IN THE DRAIN TROFF USE WARM WATER OR HAIR DRYER. KEEP FREEZER 0-6 DEGREES. IF PROBLEM REOCCURS THERE IS A HET PROBE TO KEEP DRAIN HOLE CLEAR. PART NUMBER 819043
Apr 25, 2010 | Refrigerators
Water builds up under the crisper drawers and I dont know why?
probably a frozen drain hole in the freezer. a heat probe usually has to be inserted to prevent the drain hole from freezing shut. part # 819043.
Feb 28, 2010 | Whirlpool Refrigerators
My Kenmore refrigerator defrost drain freezes over.
There is a heat probe kit available to help prevent the drain hole from freezing shut. Part # 819043.
Jan 29, 2010 | Kenmore Refrigerators
Water is dripping from freezer to shelves in fridge
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Jan 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
In the frezzer ice is forming under the floor and dripping down onto the floor of the refrigerator part under the veg drawers
May 05, 2009 | Kenmore Refrigerators
URGENT HELP NEEDED PLEASE
you have to upgrade the phone's software to a newer version
Mar 30, 2007 | 8x8 Packet8 DV326 IP Video Phone
Refrigerators Logo
437 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
