Question about Abit IC7 Motherboard
IC7-G MB after changing bios memory to F1 on reboot getting
IC7-G motherboard. after changing bios memory timing to aggressive on reboot getting long beep. NO DISPLAY on monitor to fix problem. Reset button doesn't help getting into BIOS
  • 198 Answers
You'll need to reset the Bios.
Take the battery out inside, it's usually on the lower right of the motherboard, it looks like a watch battery.
Unplug the computer and press the power button to get rid of any extra juice from your power supply.
Wait about a minute.
Put the battery back in and plug your system in, the reset should be complete.
Some motherboards have a pin setup to reset the system. If the jumper is in (oox, x being the free pin) for example, then just switch the jumper to (xoo), turn your computer on...nothing will happen, all good.
Put the jumper back from (xoo) to (oox) and it should be reset.
Keep in mind, doing this a lot isn't good for the system. Make sure you know how to switch up the options in your BIOS.
Posted on Jul 16, 2009
  • Mixplyxit Tigerbait Jul 16, 2009
    Forgot to mention, before you put the jumper back from (xoo) to (oox). Turn the computer off.
    You probably already know that, just making sure.
    MDD.
I have finish f1 key in system plz help me
Hello.
Please provide more details about your problem.
If you are seeing the "F1" prompt soon after turning the computer on, it is likely preceded by details of what has occurred and wants you to confirm the change. Reboot the computer and look at the entire screen and provide the details on the screen so we can help.
Until we get your exact issue, I will cover the basic reasons why you would see
If the message states the DATE AND TIME are incorrect, you will need to replace the small round battery that is on the motherboard. These are typically a battery with 2032 written on them and you can pick them up almost anywhere watch batteries are sold. Replace the battery, boot the computer and then go into BIOS and set the correct date and time.
If something has failed on your PC (like a stick of memory, hard drive, CD ROM drive, etc.) the BIOS would see this change and would prompt you to acknowledge this change and either hit F2 to go into BIOS and fix the issue or F1 to continue booting the computer. IF this is the case, note what has failed and then go into BIOS and either disable the drive or accept the new memory value.
Oct 31, 2013 | Dell OptiPlex GX280 PC Desktop
I had 2 x 512mb memory installed with no problems. I recently installed 2 x 1Gb but the bios does not recognise it. The pc always hangs on boot up just before loading windows. The pc will work with the 2 x...
Hello gphillips397!
Abit has released an updated BIOS for the IC7-MAX3 motherboard which fixes quite a few issues with your motherboard including one that can cause the system to hang with certain memory modules. The updated BIOS is HERE and instructions for the upgrade are in Appendix G of the User Manual or a general guide is HERE
Nov 22, 2010 | Abit IC7-MAX3 Motherboard
How do I reset bios on this motherboard? I've tried to find a user manual to download without success.
This link to Abit will get you the manual for the IC7-MAX3 board, which may what you need.
If by resetting BIOS you mean clearing CMOS, just remove the battery.
Feb 14, 2010 | Abit IC7 Motherboard
IC7-Max3 with 2x512Mb OCZ PC4000 memory sticks (184 pin DIMM). Only registered 512 Mb. Vacuumed dust and cleaned. Now won't post. Cleaned memory sticks with eraser. No beep. Recovery path?
vacuums can cause static electricity. this may have damaged your motherboard in some way. you have to use a special anti-static vacuum when cleaning electronics.
Dec 26, 2009 | MSI 915P Neo2 Platinum Motherboard
Computer continiously ask for reboot
DFirst thing to do is to UNdo everything you have just done: Memory Upgrade and CPU Cooler. If normal operation returns, try the upgrades, one at a time, to narrow down the source of the problem. I suspect the memory, as a DIMM chip not correctly set up will cause this problem. Let me know what it does, please? jaye.ellen@gmail.com
Dec 12, 2009 | ASUS P4SP-MX Motherboard
Can't install operating system keeps looping
Is it possible that you have your boot device set to the CD ROM and it just keeps loading the OS off the CD. Try changing the boot drive in the bios to your C drive when the computer does it's first reboot.During the install.
Oct 14, 2009 | Abit IC7-G I875P;SOCKET 478;800MHz...
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
Jun 05, 2009 | Dell /Poweredge 6650 BackPlane 2+3 Board...
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
SHARED VIDEO MEMORY
go to this site http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1810 and download the manual, it should show you how to change the onboard video settings
good luck
Terry
Mar 05, 2008 | Gigabyte GA-K8VM800M Motherboard
Abit IC7 Motherboard Logo
168 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
