Question about Cell Phones
How do i erase all my contacts? - Cell Phones
    Problem Solver:
  • 14 Answers
Go through every contact and selet one at a time after you selet it a list should come up and the option delete should beon it.
Posted on Jul 16, 2009
Tip
Cleaning PC Desktop Memory Stick Contacts
The best way to clean the contacts on computer memory sticks is to use an eraser.The contacts on memory sticks get tarnished after being exposed to the elements especially inside a computer where theirs a lot of air flow happening so cleaning them with a pencil eraser will restore the contacts to allow good contact between the stick and the memory slot.This also works for any electronic equipment that utilizes flat male/female connectors like in tvs,garage door openers.Make sure that only the eraser comes in contact with the connections and be careful that you do not hit any of the smd(surface mount devices)located on the board.If your not comfortable using a pencil eraser you can get the same results by using just an eraser itself.I would recommend that if your using a pencil eraser that it be a brand new pencil,do not use a pencil whose eraser has been worn down,due to the erasers metal holder which if not careful can scratch and/or damage the piece being cleaned.This also applies to Laptop memory.Thanks and Enjoy
on Feb 12, 2011 | Computers & Internet
How can I delete iPhone contacts permanenlty before selling?
You want to compelely delete iPhone contacts, however there's a professional iPhone contacts erase software you need to be cleared wholly. Take this guide will help you. http://www.vibosoft.com/ios/how-to-erase-contacts-from-iphone.html
Aug 18, 2015 | Apple iPhone Cell Phones
How do i completely remove contacts from my iphone?
There is no mass method for deleting contacts that are already registered on a phone.
Each contact will have to be individually deleted or edited to record details of your contact.
The process to edit or delete a contact individually is exactly the same as follows:
Open your phone Icon
Open contacts
Select an individual contact
Click Edit
Modify the details as required and touch Done
or
Scroll to the bottom of the contact list and Select Delete Contact
You will be prompted to Delete Contact or Cancel
The contact will be removed.
Repeat the process for Editing or Deleting each contact on your list.
Sep 22, 2014 | Apple iPhone4 4G iPhone 4
I want to delete the contact in my LG GS290 mobile
Have a nice day.
Here are the ways to delete the contact/contacts in your mobile phone:
From the main menu screen, press Contacts [Right Soft key].
Press Options [Right Soft key].
Select a contact from the contacts list.
Press the Right Soft key for options.
Scroll to Manage Contacts, press OK
Select Erase, press OK.
Press Right Soft key to select all or select desired contacts to erase by pressing OK to mark each contact.
Press Left Soft Key for Done.
Display shows Erase Contacts?
Select Yes, press OK.
Hope it can answer your question,
Thank you for using fixya.
Adieh
Sep 12, 2011 | Cell Phones
I CANT DELETE CONTACTS lg gs290
If this does not work, "Power the phone off for 30 minutes and then power it back on and try it again."
Regards
Jul 18, 2011 | Cell Phones
How do i delete my contacts
Use the Security Menu to quickly erase all the contents of your contacts lis.
1. Pess MENU>Settings/Tools>Settings>More...>Security and enter your lock code.
2. Select Erase/Reset>Erase contacts.
3. If you are certain you would like to erase all you contacts entries, select Yes.
Mar 08, 2011 | LG RUMOR Cellular Phone
On boot up I get 4 short beeps what is the computer telling me.
That's your cell phone.
JUST KIDDING!
The beeps are BIOS Beep Codes.
4 short beeps means the same thing as 2 short beeps.
Problem with the Ram Memory.
Computer off, and unplugged from power - Desktop
Computer off, and all power removed. Remove the AC adapter (Charger) and Battery - Laptop
Suggest you remove all Ram Memory modules, and clean the gold plated contact pins on the bottom, with a pencil eraser.
If you are not using a solid eraser, and are using an eraser on the end of a pencil, refrain from letting the metal band contact the contact pins.
Rub the eraser up, and down on Each contact pin. Both sides.
Use air to remove the eraser dust.
You can use a can of compressed air for computers if available, or air pressure from your mouth will be sufficient.
Don't worry if you cannot see that you have cleaned the surfaces of the contact pins.
Using the eraser I assure you that the eraser will clean them.
The gold plated contact pins develop corrosion on them after a period of time.
Doesn't take much corrosion to make a bad contact surface.
Reinstall the Ram memory module/s.
Close the computer case, or reinstall the Memory Compartment Cover.
Plug the desktop computer back into power, WAIT 20 seconds, turn it on.
Reinstall the Battery into the laptop, plug the AC adapter back in.
WAIT 20 seconds, turn the laptop on.
Regards,
joecoolvette
Nov 22, 2010 | Computers & Internet
How to delet all the contacts from iphone
If you are using itunes for windows and have synced your contacts with Windows address books and your contact list is now filles with all of your contacts email addresses, here is a quick way to delete your address book at once.
create 2 empty text files on your desktop and rename them to
AddressBookimages.sqlitedb
and
AddressBook.sqlitedb
copy/overwrite these empty files into " /var/root/Library/AddressBook" folder, using "Ibrickr"
this will empty your contacts list, since all contacts are stored in those two files.
* This wont take effect untill you restart your phone
Jan 04, 2010 | Apple iPhone Smartphone
Error 99 can't make a shot
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Oct 26, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cell Phones Logo
495 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
