Question about GE Dishwashers
Dishwasher buzzer will not turn off. no lights on display, buttons have no effect, and killing power to dishwasher does not reset board.
  • GE Master
  • 3,361 Answers
You may be able to cancel the cycle buzzer by pressing the HEATED DRY button 5 times in 3 seconds. You should hear a 3 beep signal. If not your control board will have to be replaced.
Posted on Jul 16, 2009
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Installed a new control board in GE dishwasher: GLD6860NSS. Still having problems!
check the board for a dry joint where wires are soldered to it. I researched this problem before. It was where one board was wired to another. Bad joint was not supplying enough power.
Mar 23, 2017 | GE GLD6860NSS Stainless Steel Dishwasher
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Dishwasher start button has no effect: Whirlpool DU1100XTPS1
This is a problerm caused by the main control circuit board that is behind all the control buttons, the part is about $150.00 and about 1 hour to replace it.
Feb 09, 2012 | Cars & Trucks
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
We have a kitchenaide dishwasher and the clean light keeps blinking off and on and the dishwasher won't work. Of course it is Thanksgiving and I have a house full of people coming over! Any ideas?...
you can try to kill the power to dw and with 15 minutes before supplying power back and see if it will reset your control, if not you will need a new control board / thanks
Nov 27, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
140 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
