Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water still going into washer
On our ultimate care II, you care hear water barely running into the washer with the washer turned off
  • 5,911 Answers
This problem is usually caused by one of the two following possibilities:
1. Water Inlet Valve. The valve is located where the fill hoses attach to the back of the washer. Over time these valves can clog with sediment and restrict water flow, or not close all the way and cause leak by.
2. Pressure Switch. The pressure switch is located behind the load level selector knob on the control panel. These switches can malfunction and cause similiar symptoms.
To replace the pressure switch you simply need to unplug the washer and remove the back of the control panel to access. There's an electrical connection and an air hose you need to remove.
Replacing the water inlet valve requires a little more effort. The following link explains:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
A simple way to determine which component is causing the problem is to unplug the washer. If the problem stops, it's probably the pressure switch. If the problem continues, the water inlet valve needs replaced.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Jul 16, 2009
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate Care II toploading washer doesn't empty or spin after ag
Hello, I can help.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer
hi thanks for your question. how do you turn the water off with the taps. i think you have a water level problem .check the water level switch thanks the appliance doc
Oct 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
