Question about Philips Magnavox MWD7006 DVD Player
How do i connect it.. i lost instructions,,, and i cant get in to work. i got direct tv and the tv only has on cable comeing from it,,going to the direct tv box,, so i put the colors where they go to the dvd player and it still don't work help. magnavox mwd 7006 dvd player,,i need diagram how to do it,,
You need a RF modulator, a set of audio wires with m/f connecting ends and a cable wire from the device to the tv.
Posted on Sep 03, 2009
How to connect to at&t uverse cable box
did the box come with a cable and instructions .read instructions then attach cable where it suggests they go . set tv input to that cable and it should work .
Oct 01, 2015 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
I just need the basic wiring instructions for hooking up the direct tv, an x box, and how I'm suppossed to go from tv to reciever and the monitor out cable. I have a samsung txr3079wh flatscreen. I also...
Connect the Direct TV and the Xbox directly to the television by their respective video cables.
Then connect their audio cables to the audio inputs on the receiver.
This connection method does not require use of the monitor out terminal.
Sep 09, 2010 | Pioneer VSX-818V-K Receiver
I cant get sound out of the Bose V30 and i lost the cable picture on Tv. What do i do?
I lost the video (HDMI) but can get all my sounds (TV, DVD, Radio, etc). HDMI cable is fine because it worke when plugged from cable box directly to the TV. Any suggestions?
Dec 22, 2009 | Bose Lifestyle V30 Home Theater System -...
We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Nov 17, 2009 | Televison & Video
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
Hooked up my new aquos and cant get the cable to work, my wii comes on , my dvd player too, but the Direct Tv screen is just blank
How is the cable connected to the TV. Is it direct into the back of the TV or through one of the connections like say the wii? Did it work before with the way it is connected?
Aug 18, 2008 | Televison & Video
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
Ps3 60gb setup problem.
I have the same problem, I was told to buy a HDMI CABLE I did
but it still wont work
Dec 27, 2007 | Sony Playstation 3 (PS3) Console
Philips Magnavox MWD7006 DVD Player Logo
291 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
