The fill level sensor has probably failed. If you open it up, you should be able to find the sensor. There will be two of these (full and empty)- they are usually disk like object ~ 2 inches in diameter, with a rubber tube coming from the centre. I would try swopping them over. If the fault moves from 'not stopping filling' to 'not trying to empty' (or similar change) you have found the fault. Buy a replacement from an on-line spares supplier.
SOURCE: water keeps draining
You may be experiencing what is known as "siphoning". If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain. You need an air gap in order to prevent this. Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches. If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests. Makes sure there is still an air gap around the hose. That is, make sure the hose isn't seated so tight that it seals off the standpipe completely. This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening. Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe. In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor. If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here. There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem. You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise. This is air being reintroduced through the drain line. I hope you find this information helpful.
SOURCE: Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
SOURCE: stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
SOURCE: Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
