Question about Whirlpool Dryers
Whirlpool eletronic electric dryer runs for about 1 min. shuts off E1 displayed
    President:
  • 1,714 Answers
The E-1 code is: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E1 Keypad keytail not connected.
So that means you need to get in the dryer where yo can assess the back of the key pad and check the connector.
Posted on Jul 16, 2009
  • Craig Butler
    Craig Butler Jul 16, 2009
    So i found some more info for your machine and it says the 'thrmistor' is bad. The thermistor is located by your main operating thermostat inside the dryer housing. Write back if yo need more info
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore dryer repair runs 1 minit shuts off E1 replaced thermister still shuts off
disconnect the vent hose and run dryer, as it sounds like there is a restriction. Hope this helps Tim
Here is a link that may help Kenmore/Whirlpool same:
http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
May 10, 2011 | Kenmore HE5 Electric Dryer
Whirlpool Duet dryer runs for 1 min. and then shuts off with e1 error, I did some research and found out their is a thermal fuse located behind the lower panel. Also something about a the heater could be...
E1 error code is a problem with the thermister sensor is is located behind the lower front panel..you do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Aug 22, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L00 Electric
the dryness sensor is bad, replace them and it will be fine ,,, Larry
Nov 01, 2008 | Whirlpool GEW9250P Electric Dryer
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
