Question about Cell Phones
How do i access t-Zones from the sciphone
can't access t-zones from sciphone
When i try to bring up google i get no site configured
Method 1: Try adding the website to trusted sites and check if he is able to access the websites
Security zones: adding or removing websites
http://windows.microsoft.com/en-US/windows7/Security-zones-adding-or-removing-websites
Method 2:I would suggest you to try the steps from the following link:
Cannot access some websites in Internet Explorer
http://support.microsoft.com/kb/967897
Dec 09, 2013 | google.com
Russound CA6.4i zones failing
They should be. I would replace the electrolytics for each of the failed zones. If you do not have a tester, just replace the electrolytics out of hand. The intermittent sound suggests one is likely shorted but not completely or has opened up internally- but not completely.
Sep 21, 2012 | Russound Audio Players & Recorders
Phone programming is only offering 3 page zones. Manual says that I have the option for 6 different page zones.
"I should have 1-6&none."
How so?
It all depends on your software release and system size/model.
Aug 10, 2012 | NorStar T7316E Corded Phone
I am looking for windows messenger help i cant access my hotmail to access my emails i keep getting an error message
Here are a few things you can try. If you have two accounts on the PC, try to logon into both to see if the problem occurs on both. If you don't have two accounts, create a second one and try it. Check those internet security settings to see if any of the buttons are greyed out. If it only happens on one account, check and compare the registry registry settings below to see if they match and see if they match those of the working account.
"HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1"
"HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2"
"HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3"
"HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\4"
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1"
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2"
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3"
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\4"
Good luck.
Aug 16, 2010 | Microsoft Windows Live Messanger
Touchpad Scroll zones not working
we can uninstall the drivers from device mgr and then reinstall from HP.COM.
do a BIOS update
Dec 13, 2009 | HP Pavilion dv4000 Notebook
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
I have an unlocked lg viewty and i have t-mobile web access but it wont let me in to any websites it keeps saying error
http://tmobileuspublic.wdsglobal.com/phonefirst
Go to that link. Its a configurator that can send the correct settings to the phone. Just select the manufacturer and model and follow the directions. What is the specific error? Just Error? If its something like http $code$ error then thats a network error, not phone.
If that doesnt work try this manual setup:
Setup Access Point:
  • From the Main menu go to Tools > Settings > Connectivity > Network > Access Points
  • Create New or Edit existing
  • Set the Name to T-Zones
  • Set the Access Point Name to wap.voicestream.com
  • Note: If you signed up for Total Internet, use internet2.voicestream.com or possibly internet3.voicestream.com
Setup Profile:
  • From the Main menu go to Browser > Settings > Profiles
  • Set the Profile Name to T-Zones
  • Set the Homepage to http://wap.myvoicestream.com
  • Set Connection Mode to TCP with Proxy
  • Set the IP Address to 216.155.165.050
  • Set the Proxy to 8080
  • Set Access Point to T-Zones
Aug 23, 2008 | LG Cell Phones
Honeywell TZ-4 Misbehaving
there is a "zone a lone" switch on the upper right side of the panel. Make sure it is in the "occupied" position. I believe that is up. If that doesn't work reply back.
Feb 29, 2008 | Kitchen Ranges
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Samsung U600- WAP and MMS settings for T-Mobile
I have had a similar problem when I first got my unlocked phone. I have T-mobile as well, and once they find out you have a phone device not purchased by them, they are not very helpful - they will give you their default mms settings(same ones listed on their site). I tried those settings and they did not work on the particular unlocked phone I had. I did some extensive web searching and came across a few settings that worked with my phone. I will list them here. Hope they work for you!
*MMS Settings: Home URL - http://216.155.174.84/servlets/mms
*Protocol Type - WAP
*WAP IP Address - 216.155.165.50
*GPRS Access Point - wap.voicestream.com
*GPRS Username - Leave Blank
*GPRS Password - Leave Blank
*Authentication Type - normal
*T Zones - http://wap.myvoicestream.com
Nov 03, 2007 | Samsung Cell Phones
Cell Phones Logo
124 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
