Question about Daewoo 19NF 19 in.CRT Conventional Monitor
Out of focus
Hi;
The problem is quite sinple I think. My computer screen appears fuzzy or out of focus. Average size writing is hard to read, we have to zoom in to read smaller print. Is there a way to fix this? I tried to download a user manual but I can't figure out how that works either. If you can help thank you.
    Brigadier General:
  • 6,966 Answers
Your display being fuzzy as you described is indicative of either:
a. weak picture tube; or
b. component failure or deterioration.
Even if it were a weak picture tube or deterioration, it is still possible to "squeeze" a few more usable time out of the monitor. You simply have to adjust the focus control. Normally, this is accessible from the rear of the electronic circuit board and is a part of the Flyback transformer (FBT). Below is an image of a sample FBT. Pls notice the two (2) protrusions, one of them is marked as Screen and the other as the Focus. You need to adjust the focus till it satisfies your visual requirement/preference.
A word of caution. This procedure is not recommended if you have no TV/Monitor repair experience. It is not a fix. It is as earlier stated, squeezing in just a few more usable time. The unit would have to be adjusted "live" with the cover off. You need to be familiar with electronic components, tools and circuitry as well as working with powered devices and extremely High Voltage. The monitor may have to be operated with insulated support since the back cover will not be attached. Additionally, you may need to use a mirror to check if you adjusted it as you want it.
As you try to adjust it with an insulated screwdriver, you will notice that there is mid point where the focus will just be about right. You may have to adjust a couple of times to get the setting as you want it.
Should you feel uncomfortable doing this, perhaps you may need to seek the assistance of a qualified TV/Monitor technician.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 18, 2007
  • Louie  Role
    Louie Role Nov 28, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
    Cheers.
Sony KP65WV60 CANNOT RECONISED RED COLOR AND WRITING FUZZY
First, try cleaning all your lenses & mirrors...THEN
considering the age of this unit, the red CRT is probably worn out. Weak CRTs are probably the problem with the fuzzy picture also.
You can try to adjust your screens (the screen adjusts are available by removing the bottom front) to bring in some red, and adjust the focus on each CRT for better focus. I'm thinking with the age of this unit you may need more than just the RED CRT.
If any parts are needed, My recommendation is to replace the unit with new technology. Would be more economical in the long run.
Apr 29, 2014 | Sony KP-65WV600 65" Rear Projection...
My sony kp65wv600 cannot see any red on people in pic and writing fuzzy
Canon 50D. Hi, When I look through the viewfinder the top edge appears fuzzy. There is no problem with with the actual pics.
The focus screen might be loose.
Here's a video about focus screens. Maybe you can adjust it.
Happy Shooting!
Mar 06, 2011 | Cameras
Cant hardly read the screen the printing is so small and a little fuzzy
Change the display font size. In Win 7, right click on the desktop and choose Screen Resolution then choose make Text and other items larger or smaller. This brings up Windows Appearance and Personalization > Display (small, medium, large buttons). With Win7, you can also turn on Clear Type for LCD displays.
The earlier versions of Windows have the same display font option but it may be a subset of the Accessibility Control Panel. Macs probably have a similar control in the OS.
I hope this helps.
Apr 17, 2010 | Compaq Computers & Internet
Fuzzy picturethe
If the colors appear to be aligned and the only isue is focus, than you can adjust the focus on the flyback transformer. Carefully remove the rear cover and locate the flyback transformer (part with large red wire coming out the top). There should be 2 controls/adjustment points on it. One is for screen and the other for focus. Try adjusting the focus using a mirror to see the front of the set. You should adjust the control back and forth a ferw times to "loosen" it up a bit before settling down to the focus point.
Update this with the results.
Dan
Nov 30, 2009 | Zenith R57W46 57" Rear Projection...
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
27'' RCA appears out of focus on the vertical Edges of the Screen
I've seen this on many computer CRTs as they age past 6 years. I would imagine that the gun alignment is out. Are all the colors (RGB) fuzzy, or is it hard to tell?
1. Sometimes, extreme settings of contrast or color (usually to offset low output from aging CRT) can appear to unfocus your screen. Adjust color/contrast down if they are maxed out or close to highest setting/pot level.
2. A very likely culprit is unshielded speakers are too close to the screen. If this is the cause, the speakers' magnets distort the part of the screen closest to them (sides), and it will get better/worse as you move the speakers away/closer to the TV. If there are not magnets near the TV, and degauss function does not fix problem ('89 TVs have degauss?), see #3.
3. The focus can be set by adjusting the flyback transformer. As an experienced electrician, you should know about the dangers of messing with the insides of the unit.
If this fails, you might have other bigger issues. I'd suggest a nice trip to lead reclaimer if so. I'd say 19 years is quite a life for a CRT.
Nov 12, 2008 | RCA F27440 27" TV
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Unclear images
Remove the rear cover and adjust the focus control on the flyback. Use a non-conductive probe, available as adjustment tools from any radio shack. On the FBT (Flyback Transformer) you have two protruding adjustments - one marked screen, the other focus. The screen adjustment increases the G2 voltage to the crt and brightens the picture by increasing the voltage exponentially. You don't want to adjust the screen voltage. The other is the focus, you can easily turn that clockwise or counter clockwise and watch the screen to set it at your preference.
Hope this helps.
Bill
Nov 11, 2007 | E-Machines 17F2 17" CRT Monitor
Daewoo 19NF 19 in.CRT Conventional Monitor Logo
2,043 people viewed this question
Top Daewoo Computers & Internet Experts
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
