Question about Husqvarna 23 Hp 48" Deck Yard Tractor
I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC TRANS. IT WILL NOT GO FORWARD OR REVERSE. USED MANY TIMES NO PROBLEM AFTER SAT TWO WEEK WONT MOVE
  • 11 Answers
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • sahenry473 Mar 13, 2011
    Same problem, Front two support bolts on the rear axle came loose and fell out allowing the entire axle housing to move. Threw a belt. Fast in reverse, very slow in forward.
    Replaced bolts. All good again.
Has very little power in reverse.
sounds normal to me none of that type run fast backward
Apr 22, 2015 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Riding mower no longer moves.
If this is a hydrostatic transmission, one of 3 things:
1. Drive belt off pulleys (recommend replace belt if so)
2. Belt broken (obviously, replace)
3. Hydrostatic transmission failed (least likely, but this is an expensive repair shop issue if so)
This happened to my GT1554 two weeks ago - fortunately, replacing the belt resolve the problem.
Oct 19, 2012 | Cub Cadet Garden
Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Oct 03, 2012 | Husqvarna "GTH24V52LS 52"" Kawasaki 726cc...
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
Husquvarna hydrostatic mower won't move
Sounds like the belt going to the hydrostate broke. Or a key on one of the pulleys broke. The belt runs inside of the frame and is hard to see.
Jul 11, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
530 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
