Question about Brother IntelliFAX 4100 Laser Fax
Lots of dark black vertical lines down the right side of the page - both when receiving a fax and when copying
Drum unit needs replacing
Posted on Jul 17, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Faxing problems
Check the scanner glass for ink or lint residue. This is what normally causes lines on faxed and scanned documents and pictures. Here is a link to explains it and shows where to check for the residue.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Jul 27, 2012 | Lexmark X6675 All-In-One InkJet Printer
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
383 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
