Question about LG enV VX9900 Cellular Phone
Vx9900 wont power down
It stays on and neither power button works when i take the batt out and put back in it just comes on bye its self need help
  • 106 Answers
Re: vx9900 wont power down
Exact same problem i had. If you have insurence on your phone just call up the insurence company and they will replace it for a small fee. i belive like 25 dollars or see if your phone company will do it
Posted on Nov 27, 2007
0 characters
3 Points
How to hardreset telego phone
To Enter "Android System Recovery utility"
1. Power off phone then remove batt for 5 secs
2. Put the batt back
3. Press and Hold Volume Down then Press and Hold Power
4. Press and Hold both button until Telego Logo appears
5. After the Telego Logo appears recovery logo will appear and release Hold on both button
6. On recovery logo press up to open the "Android System Recovery utility"
7. To navigate use Volume up and Down and power to select Option
8. Now just select Wipe Cache / Wipe data Factory reset and reboot. youre phone is now back to normal
Aug 04, 2014 | Cell Phones
LG ENV VX9900 crashes
Hello there.
If the phone is not turning on thats a bad sign.
Before taking the handset back to where you purchased it, try holding the power button in to soft-reset it. From the sound of your description the phone may need replaced.
Hope this helps.
May 05, 2008 | LG enV VX9900 Cellular Phone
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
PLease do a hard reset on the phone and here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 04, 2011 | HTC 7 Surround Cell Phone
My iphone was acting up so I rebooted it and now it wont turn back on the apple will come up and then the circles thing like its loading but then the screen turns black and wont turn back on!! I dont know...
Try powering off your phone and then when its off, hold down your power button and the button on the front of the phone until the apple logo appears and wait a little, it might take a while for your phone to boot up to home screen and to get a signal so just give it time to catch up with it self :)
Hope this helps & give me a message back if you have any question or it doesnt work! :)
(Please Leave Feedback)
Jan 07, 2011 | Apple iPhone Smartphone
Battrie dies with in the 1st hour of use off charge
Friend, there is a problem in your battery and needs to be replaced. But before doing so just try my tricks of fixing a drainable battery. I have experienced this many times and it works again back to normal. All you have to do is drain the batt,to empty a real empty then cover the battery with a newspaper or any paper.make it thick put a tape if possible.then put it in a saucer or a plate covered with another plate or saucer then put it inside the freezer of the refrigerator.for at least overnight.or 12 hours.then after putting it in the freezer remove the battery so as the covered paper and let it dry if posible under the heat of the sun at leas 3 to 4 hrs as long as it is already very dry then put it on your phone and charge it within 8 hrs.then after that it will make the battery back to normal.This is true ive been working for this i am mobile phone technician in the phils.for quiet a long time.
May 01, 2009 | LG enV VX9900 Cellular Phone
The screen on my lg webslider wnt work??
the problem is very broad my dear, it can be the POWER IC, or AUDIO IC or SIGNAL IC,, you better go to technician in order for them to find the defected IC on your fon
Apr 01, 2009 | LG enV VX9900 Cellular Phone
Mp3 player
1. The EnV can only play .wma and .mp3 files .. make sure no other filetype (music) exists.
2. try formatting the card before putting music on it. Make sure all your files are backed up somehwere as formatting= erasing
3. power down the phone .. Take the battery out ... then put the battery back in and power it back on and try it again .... if it fixes your problem then you were having a software glitch
Hope this helps.
Dec 30, 2007 | LG enV VX9900 Cellular Phone
Can't power up or off.
i just brought it to verizon and they gave me a new phone
Oct 05, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
