SOURCE: 2001 jaguar vanden plas transmission problems
hello sir
excuse me sir
here is too much video but i am giving you only one
this will help you
and sir this one is the full list
just check it out
http://www.youtube.com/results?search_query=how+to+fix+cars+transmission+problem&search_type=&aq=f
SOURCE: 1999 F350 crew cab 4x4 ford, gear shift lever
Ok ready to stand on your head under the dash?
It's doable... there is a flange connected to the gearshift lever under the steering column. If you remove the lower dash cover where the fuses are, you should be able to see it when you move the gear shift lever... look around on the floor of the truck to see if you dropped a star-headed bolt or two... these bolts worked loose on my superduty and made shifting very difficult..it was an easy fix... let me know how you do on it.
SOURCE: My 2001 Ford Mustang v-6 automatic gear shifting lever wont move
The shift interlock does not allow the car to shift out of park unless the brake pedal is depressed. Quick fix is with the car running to set the parking brake and turn the car to off and remover the key. Put the key back in and turn one click to on. Shift the car into neutral and you can start the car and go. The repair for this is either the brake switch located on the brake pedal being replaced. I had a broken wire leading to the switch that caused the problem. It also can be a blown fuse.
SOURCE: 2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
SOURCE: 1997 Chevy Cavalier with automatic shifter not working
that would be your shift lever assembly and yes it can bwe fixed and its fairly easy
