Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • Duncan33 Feb 02, 2009
    I cleared my filter of coins etc. Pump is pumping out, but will not stop pumping. Still code 15. Could this be PCB?
  • 76 Answers
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Posted on Nov 19, 2007
E15 during a wash
'E15 Check outlet pipes
check the filter and all pipes and there are no blockages
Feb 10, 2013 | Hotpoint Washing Machines
My hotpoint ultima extra washing machine says e15 check outgoing pipes i have cleaned the pipe out and is washing to a certain point then e15 shows and starts to beep continuously
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Aug 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
E15 eeror message
If Hotpoint or Creda check for:
E15: Water not pumping out, or pumping out too slowly. Check pump for obstruction or foreign objects jamming pump, or kinked drain hose, or blocked outlet/U-BEND.
Feb 24, 2010 | Hotpoint Washing Machines
I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Jan 19, 2010 | Washing Machines
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hotpoint MODEL WM75PR error code E15
E15 "Check Outlet Pipes". Normally this is a blockage in the pipe or the filter connected to the drum.
Error code 15: Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not
What you need to be sure of, is whether when the error telling you to check for blockages in the outlet pipes happens, it's actually an accurate indication of the fault. I dislike these stupid error codes as they often fire off erroneously and cause no end of trouble.
It can also mean a faulty control panel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2009 | Washing Machines
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer dryer
1. Turn off power
2. Turn off hot and cold inlets if possible - if not then pop outside and turn off water to house
3. Unscrew all the screws on the back of the machine to take off the rear panel
4. Use a large pair of pliers to remove the clip securing the large black rubber hose to the drum chamber.
5. Remove sock. Trust me, it's a sock :)
6. Put it back together.
If there is no sock (but I'm sure there is) then work your way through the drainage system until you find the problem. I once had a label from a baby grow in the fan blades of the pump. The drainage is pretty self explanatory. There's only the internal black hose with a filter in, then the pump, then the external hose. If there really is no sock then check them all.
Jun 30, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
259 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
