Question about Kenmore Dryers
Kenmore dryer 90 Series is not heating. - Kenmore Dryers
    President:
  • 1,776 Answers
This sounds like it could be the thermal fuse or the heating element. You can check the thermal fuse and heating element for continuity with an ohm meter. No continuity would be bad. The fuse is usually located close to the duct. Hope this helps.
Posted on Jul 16, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
372 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
