Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Won't Read blank disc!!
Error message reads "This disc can be neither played nor recorded. Please check the disc. [EC:0207]" I have the correct formatted disc and have tried various types of Dvds. I have also recorded on this unit successfully before. Problems have risen over the past two weeks and refuses to go away. Any suggestions? DVD Recorder HR753 worked perfectly for two months after I bought it in August 2007.  Now, using the same discs I used previous it rejects all new discs I try to use.  So, I can record onto the hard disc but not onto a DVD nor can I copy from hard disc to a DVD. Please note that my machine is DVD-HR753 which I cannot find in the drop down menu below.
  • 9 more comments
  • Anonymous Nov 25, 2007
    I have a similar problem with this recorder. The Hard Disc works but trying to record from the Hard Drive to a -R Blank Disc is very tricky. It depends on the Manufacturer of the blank disc. It will record on Memorex DVD-R BUT if I try to use a Philips DVD-R Disc it tells me that the Disc can neither be read or recorded. I do not understand that some manufacturers DVD-R blank discs will work and others will not.
    Peter Hardcastle
  • lewy351 Feb 12, 2008
    mine wont read any discs at all
  • Anonymous Feb 19, 2008
  • kartellcomm Feb 28, 2008
    Facing a similar problem. Samsung Model DVD-HR753. Manual says that this model can record on DVD-RW and DVD-R. But the recorder does not accept either of the format and the blank media is ejected after a few seconds. Used SONY DVD-R DVD-RW discs. Any suggestions to get over this problem.
    Suresh ([email protected])
  • AshLew May 15, 2008
    Exactly the same problem i'm having. Can you just buy a replacement DVD writer and swap them out and if so where can you get one from.
    OK. Took the unit apart and thought i'd have a look at the laser lens on the DVD unit. Used a cotton bud on the lens and put it back together and now its working fine. No idea how long it will last though!
  • Anonymous May 27, 2008
    Won't play any disc. After the disc is been insirted, error message reads: "This disc can be neither played nor recorded" then the tray opens again.
  • Anonymous May 31, 2008
    Won`t recognise any discs to record or play (accept a few commercial ones)
  • jackpot69 Jul 16, 2008
    i have the same problem also. ive hd the drive changed by samsung and it only lasted about 2 months before the same problem occured again
  • donbruce307 Nov 17, 2008
    I have exactly the same problem described by others. Not fixed it yet.
  • droyouchi Mar 07, 2009
    My problem is exactly the same: it does not play any original dvd.
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Posted on Aug 24, 2008
Having the same issue also. I contacted Samsung regarding a replacement drive, and they quoted $200 just for the drive and $100 for labour!
Posted on Jun 10, 2008
    President:
  • 4,402 Answers
Laser is getting weak.
Posted on Jan 10, 2008
SOURCE:
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Read error
Some recorders, especially Phillips REQUIRE using the "Music" CD's. It was a lame attempt at copyrright enforcement.
Dec 15, 2009 | Teac CD-RW880 CD Player / Recorder
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Error 0207
MIRA LO QUE TIENES QUE HACER ES BUSCAR EL MANUAL TECNICO DE ESTE MODELO, NO SEAS WEY
Nov 11, 2007 | Samsung DVDR120 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
1,383 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
