Question about Sony Handycam DCR-DVD108 DVD Camcorder
When loading the tape,it says re attach power source ???
    Champion:
  • 287 Answers
Inspect the video cassette copartment. The pinch roller retainer falls out of these and can jamin the mech .This part can be reinstalled with a little drop of nail pollish to hold it on.
Posted on Jul 16, 2009
I have four bose 901 speakers and one equalizer. I also have a peavy deca 424 amplifier. I have a tape deck with the tape monitor capabilitity. Can these work together and how do I hook theme up?
The presence of 1/4" TRS balanced phone jacks instead of RCA inputs is a problem; and the 1/4" TRS speaker output jacks, too. You'll need to acquire cables with compatible ends.
The amp can handle 4-ohm loads so running two 901's parallel on each channel would theoretically work, but I'd put them in series just to keep from presenting too low a load when you get cranking. At 230 wpc you've got the juice. From Series 4 on the 901's are very efficient.
The Tape Deck will attach conventionally to the Tape Loop on the Active Equalizer.
Once you get the physical wiring compatibility issues worked out:
Patch the Active EQ directly between any source you may be using (Amp In from the Pre-Out of the source, Amp Out to the Peavey input).
You can record the external source onto the attached Tape Deck and you can monitor it by pressing the Tape switch on the 901 EQ.
Start out at low volume and see how it works before turning it loose.
Dec 28, 2010 | Bose 901 VI Main / Stereo Speaker
My sony dcr-hc28 developed a problem where the tape will not reinsert and i get a message "re-attach power source". i re-attach, nothing changes. i remove battery, power source, re-attach, nothing...
apply a DC voltage of 5v to the tape motor at the bottom of the camcorder. you'll find two little semi-hemispheres on top of motor. trial and error to figure out which is positive.
Dec 17, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
Unable to load tape
according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem.
Thanks for using fixya.
Jul 01, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Can't open the dv tape
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Sep 16, 2007 | Canon MV850i Mini DV Digital Camcorder
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Aug 14, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
76 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
