Question about Refrigerators
Coils continue to freeze, making the top frig, warm
    Champion:
  • 287 Answers
Possible termostat failure, easy to replace. need more detals, make model etc.
Posted on Jul 16, 2009
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
Sep 05, 2009 | Maytag Refrigerators
I need to change my defrost timer as the fridge side is not working
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time defrost the ice that is blocking airflow and causing the frig to warm. Check behind the lower panel inside the freezer.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Jul 14, 2009 | Maytag MZD2766GES Side by Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Jun 09, 2009 | Frigidaire Refrigerators
Bottom of frig freezes, top is 60 degrees
Check your door fit. The gasket should be tight all the way around, you can push the door back into shape.
Apr 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Samsung French Door Refrgerator - New
Only two months old? Couldn't you complain to the store?
The way the defroster works is this: There is a defrost timer under the refrigerator. (I'm guessing based on other brands.) That turns on the defroster about three times per day. The defroster is a heating coil with the freezer coils. It heats that until the defrost thermostat gets warm; then it quits defrosting.
My guess is that the defrost thermostat doesn't turn off the defroster... that it continues defrosting until the defrost timer turns the defroster off.
So if you want to fix it yourself, dig into the defrost coils. I don't know where to look on a French Door refrigerator. Find the defrost thermostat, an inch wide unit with two wires. Test it for continuity while it is warm. There should be none. Frozen there should be continuity.
Hope that helps.
Jun 13, 2008 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
