Question about Kodak Easyshare M753 Digital Camera
Lens Error: 113,0,0,0 It won't stay on in camera mode and turns off itself in 5 seconds
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
  • 277 Answers
SOURCE: Camera Won't Stay On
hi change the battries good luck
Posted on Apr 17, 2006
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
t00nz
  • 4738 Answers
SOURCE: Error Code: Lens Error 113,0,0,0
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Posted on Feb 03, 2008
  • 3 Answers
SOURCE: lens error
ave you tried replacing the batteries with new, fully charged ones? when the battery is low the lens will just stay out because there isn't enough juice for it to retract, but you can still browse your photographs beacuse it uses less power.
Posted on Oct 10, 2008
SOURCE: problem with the lens
i had a canon for a few years and then it suddenly had the lens error message that wouldnt go away no matter what. i gave up and got a new one a few months ago and now i got sand in the new lens. instead of taking apart the new camera, i decided to dissect the old one and IT WORKS! i cant believe it. i removed all the screws and blew some air into the lens and it just worked. new one doesnt seem to come apart as easily, but at least i have something to use in the meantime.
Posted on May 22, 2009
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
M753 LENS ERROR. 101, 1,0,0
Copy and paste this website into your browser for solutions:
Nov 14, 2011 | Kodak Easyshare M753 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
When I turn on the camera, for few seconds it shows the image trough the lense, but inmediately it seems to turn off, and this legend apears on the screen: D5 f 08 5 f 0a 5e02 5 f 085 e02 the battery is...
The error is a lens motor error. The lens is not able to properly move and the camera then gives the error message. Sometimes dirt can be stuck in the lens or it could just be a mechanical problem that needs repairs. If you point the camera lens toward the ceiling while turning it on this could help alleviate the problem. If you cannot do anything to get the camera to stay on you may need to contact Olympus for repairs.
Feb 08, 2011 | Olympus Stylus 710 Digital Camera
When I turn on my camera, it comes up with "Lens error". What does that mean?
HI. One possible reason for this error is the camera has been switched on and the lens unit is prevented from extending itself. The camera will struggle for a second to extend the lens, then report the problem as a "lens error". I would start by Inspecting the lens for any obvious obstruction, then turn the camera off, then back on again. Usually, simply switching the camera Off and On again will correct this problem. If that doesn't correct the error, Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day. You are basically forcing the cameras micro board and chip sector into a reset mode when preforming this procedure.
  • NOTE_ If none of the procedures above produce positive results, I'm afraid that this unit will need to be sent to the manufacture for a serious repair detail, due to mechanical lens failure. There are no user serviceable parts on these units
Aug 16, 2010 | Cameras
First a black screen, then a lens error
For the lens error:
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
