Question about D-Link DIR-625 (790069292637) Wireless Router
All of the computers are losing their connection to my network
All of the computers on my wireless network are losing their connection including the main PC that is hard wired to the router.
How can I tell if the router has died or is dying? We lost power a few days ago and hasn't transmitted correctly since. The router is plugged into a good surge proctector but could the power problem have killed the router?
  • 1,511 Answers
Are there any lights on the router?
if yes then may be your router survived and restarting the router may fix your issue
if there are no lights then it means either your router has died or the power supply adapter is faulty.
Thnx and please rate this solution
Hope you find it helpfull
Posted on Jul 16, 2009
    Genius:
  • 1,341 Answers
There is a high possibility the router has reset itself.check internet connection direct from modem to start with and work your way back.You might need to go into your router configuration setting and check and make(if needed) some changes, check encryption or increase channel etc..
Why does my laptop lose Homegroup connection every few minutes then reconnects? the other computer in the Homegroup however does not lose connection. I am using windows 7 home premium.
Method 1:
Step 1: Start your computer in safe mode with networking and check the functionality.
Starts Windows in safe mode and includes the network drivers and services needed to access the Internet or other computers on your network.
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
If it works fine in safe mode with networking, perform clean boot to find the root cause.
Step 2: If it works fine in safe mode with networking, perform clean boot to find the root cause.
To help troubleshoot error messages and other issues, you can start Windows Vista or Windows 7 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
NOTE: After you check the functionality in clean boot configure Windows to use Normal startup using the step 7 suggested in the link mentioned above.
Note: Do Not disable wireless services, if any.
Method 2:
You may try the steps from the following link and check:
How to reset Internet Protocol (TCP/IP)
http://support.microsoft.com/kb/299357
Oct 12, 2014 | Computers & Internet
Losing network connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
Feb 18, 2011 | Linksys WRT120N Router
When i unplug lap top lose enternet conection
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 23, 2010 | NetGear DG834 Router
My intenet connection is very slow due to my router
This mentions Linksys, but it relates to all routers
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Nov 04, 2009 | Computers & Internet
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Keep losing the signal. appears that the power
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 25, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
My wireless internet connection is getting interrupted every few minutes
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
  2. Wireless settings of the router are still set to default.
  • Manufacturers suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other Linksys routers within your network range. Manufacturers suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
Thanks, Joe
Jan 11, 2009 | Computers & Internet
The actiontec gt704wg works fine
  • Placement of the router: place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Change your SSID and encrypt with WEP or WPA security.
Thanks, Joe
Jan 04, 2009 | Actiontec GT704WG Wireless Router...
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link DIR-625 (790069292637) Wireless Router Logo
241 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
