Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas
Pilot will light but heater will not ignight
I have a teledyne laars dr-325 the pilot will light but heater will not ignight. just bought the house so i dont even know if it is hooked up right. can you help
    New Friend:
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Posted on Apr 21, 2013
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
  • 33 Answers
SOURCE: my heaters pilot wont stay on and ive replaced the
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
  • 3 Answers
SOURCE: Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
Posted on Aug 07, 2010
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light went out..
Here you go... http://www.jandy.com/html/productsupport/launchManual.php?url=Lite2_LJ_IO_H0248900F.pdf
Apr 22, 2010 | Teledyne Laars Teledyne_ Laars Lite2...
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I need assistance withlighting my spa
Here is an exploded view. Open the Front panel and you will see a red knob with instructions by it. Press and hold down when you turn it to pilot. The pilot is located down and to your right ( where you light it) hold for 10 seconds then turn to on. The heater is ready for use.
http://www.poolcenter.com/parts_heaters_laars_markv_pg2_poolstor.htm
Mar 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas  Logo
208 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
