G
Gerry Conway Posted on Apr 06, 2016
Flashing light occuring in triangular symbol and printer malfunctioning. Colour ink is low or possibly out and receiving message that ink absorber is full. What remedial action can I take?
picipolman
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 12, 2016
picipolman
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
13569
Points
23
First press cancel for about 5 seconds - this way you reset the ink level error. What concerns the ink absorber error, I need to know your printer model exactly .
How can you help me fix my Canon MX320? It won't work,the green and yellow light flashing and it's says 5b00 error occurred. Can you help me please!!!
  1. Turn off the printer and unplug the power cord.
  2. Open the printer cover and locate the ink absorber. It is a small, sponge-like pad that absorbs excess ink.
  3. Use a dry cloth to gently clean the ink absorber and the surrounding area.
  4. Replace the ink absorber with a new one. If you do not have a replacement ink absorber, you can purchase one from the Canon website or from a third-party supplier.
  5. Reinstall the printer cover and plug the printer back in.
  6. Turn the printer back on and test it to ensure that the error message has been cleared.
If you are not comfortable with the process or don't have the necessary replacement parts it's better to contact canon's customer support, they will guide you through the process and make sure that the issue is resolved.
My Canon MX320 printer showing error occurred 5b00.i follow what YouTube said and now it's saying service mode. And the alarm light is still blanking. What I should do next??
The error message "error occurred 5B00" on a Canon MX320 printer typically indicates a problem with the waste ink absorber. The waste ink absorber is a component in the printer that absorbs excess ink that is expelled during cleaning and other maintenance operations. When the waste ink absorber becomes full, it can cause this error to occur.
Here are a few things you can try to troubleshoot the problem:
  1. Reset the printer: You can reset the printer by unplugging it from the power source, waiting a few minutes, and then plugging it back in.
  2. Service mode: You can enter the service mode by pressing the "Menu" button, then "Copying", then "Functions", then "Maintenance" and then "OK". Once in service mode, you can try to reset the waste ink counter.
  3. Clean the print head: Clean the print head to ensure that the printer is properly aligned and functioning correctly.
  4. Replace the waste ink absorber: If the waste ink absorber is full, it will need to be replaced.
How can I rectify canon mp210 printer ink absorber full
Are you using fine ink cartridges? Is your printer still working normally besides the flashing lights?
Error message E-1-6 lights keep flashing
Hi Stacey,
Go To Below official Canon Printer Video For Your problem and Solve your problem
Still having Problem Then follow Us For Canon Printer Support
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
2helpful
2answers
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
1helpful
Error code on my ix4000 reads 5C00
Canon has a decent trouble shooting guide for this model:
http://www.usa.canon.com/consumer/contro...
Click on the Step-by-Step Troubleshooting link under Tech Support
Unfortunately it does not give any possible solutions for blinking lights.
The user guide on the other hand does.
You can download this under Downloads -> Product / Software Manuals
Here is a summary of what the flashing lights could mean:
See Paper Jams
Six flashes: No print head installed
Install a print head.
Seven flashes: Print head is defective
Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact the Customer Care Center as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
Nine flashes: Ink tank is not installed properly
Open the print head cover and press the button of the ink tank and reinstall the ink tank properly.
Ten flashes: Battery level is low
Charge the battery. For details on how to charge the battery, refer to the manual supplied with the battery.
Eleven flashes: A specified period of time has lapsed without receiving a response from the digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME/CANCEL button and reconnect the cable.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use digital cameras or digital video camcorders that are compatible with this printer.
POWER lamp flashes alternate green and orange:
An error that requires contacting the Customer Care Center may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it about 10 minutes.
If the problem remains, contact the Customer Care Center.
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
8helpful
4answers
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
old marine
old marine
ZJ Limited
ZJ Limited
