Question about Janome 1017 Mechanical Sewing Machine
JanoneDc3018 thread bunches up .
Tryed to sew patch on jeans, the thead bunched up on the bottom then stops machine? tryed again on light material same thing like the thread was getting tangled up and stop the machine look at bottom of piece and thread tangled up?
  • Janome Master
  • 1,388 Answers
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
    Problem Solver:
  • 16 Answers
Are you using heavy thread for the top stitching? If so you will need to tighten the top tension. You would think if it is thicker thread that you would need to loosen the top tension but you have to tighten it to help pull it up through the fabric. If you use heavy thread in the bobbin you would have to loosen the bobbin tension. Check and make sure the thread is seated in the top tension and make sure there is no lint in the tension disc. It is definitely a tension issue. Hope this helps.
Posted on Aug 11, 2009
Why is it bird nesting from top thread?
by bird nesting do you mean the thread is bunching up under the material
comment with your reply
Dec 14, 2015 | Sewing Machines
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
When i sew my thread keeps pulling and breaking from the needle, seems like there is a lot of pressure on top thread and it bunches up from the underneath bobbin when sewn on material
Most of the time it is caused by the top threading, Could your thread be old, or tangled? Double check your threading by this little trick, put your tension dial on 3, totally rethread, insert a new needle (flat side facing rear). Then with the presser foot up, pull on the top thead and it should pull smoothly, now put the presser foot down, pull again, it should barely move. This usually seats the thread in the tension discs. Hope this helps.
Dec 08, 2010 | Kenmore 11101 Mechanical Sewing Machine
I have a 9420 the bottom thead is bunching up and then stopping the machine
change the needle
clean under the needle plate where the feed dogs for lint
clean the bobbin area for lint or loose threads
rethread the machine--make sure to get every thread guide
Nov 22, 2010 | Sewing Machines
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Janome 1017 Mechanical Sewing Machine Logo
209 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
