Cell Phones Logo
BARRY KENT Posted on Apr 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set up and record a message for voice mail box?
  • Official Brand Answer 1,623 Answers
  • Posted on May 06, 2016
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350735
Points
5677
Hi Barry,
With this link How do set up and use voicemail MOTOROLA PHOTON 4G LTE you can check the steps in order to set up your voicemail.
Regards,
Maya
Motorola Support
donald lee wood
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 06, 2016
donald lee wood
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
115
Points
Call your vocemail and listen to the promps and what it said
1helpful
My phone says I have voice mail but I don't
You're apparently subscribed to a voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
How to get voice mail
When I got my wireless plan, voice mail is included and mail box is set and all I need to do is press 1 and activate it at the first time. Usually you will get a menu for settings and recordings you can use to customize your voice message. It depends on which carrier you are using the operation may be a bit different.
How do I retrieve/listen to voicemail messages on my LG-P500 Android phone?
Phone require establishing voice mail boxes from were details are stored as an entity owner of device also to be mean from which communcatin sis attainable. Prior to establshing a mail box, the phone has be familiarised preferable from the user guide. usually the mails box requires for multimedia phones, a recorded voice of the owner also achievable by navigatimng the device system setting to locate an dactivarte personalmail settings. Ascertain details from the user guide that has illustrartions. Also, the is capable of provide navigational instructions of arriving at mail box area to establsih person details. Locate the phone menu settings buttons to explroe the features.
I don't know how to set up voice message
If you mean setting up voice mail out-going message, then see below (for AT&T cell service). The phone will dial the voice mail center for you after you set it. Then it will check the number of messages on the system. Press Menu > Messaging > Settings. Then select Voice Mail and enter the phone number for the call center. Then press the AT&T button to exit.
To listen to the messages, press and hold 1 or press Menu > Messaging > Voice Mail. Then the number set above will be dialed.
To set up the voice mail box, start as you would for listening to the messages above. Note: you must use your wireless phone and be inside the AT&T coverage area.
To set up your voicemail box:
1. Follow the prompts to create and enter a 4- to 15-digit voicemail password.
2. Record your name and personal greeting, then press the # key
3. After completing the setup process, press * to return to the Main menu.
See http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=browseTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=52653&isSrch=Yes for more information.
For another provider, see their documentation.
To create a memo for yourself, press Menu > Tools > Voice Memo (or if using the advanced menu, Menu > My Stuff > Tools > Voice Memo). Then press Options > New (or Create New, if you have created one before). Press Re-rec to record and pause to momentarily stop recording. Press the AT&T button to stop recording. Press Play to play back a memo and the AT&T button to stop play-back.
I hope this helps.
5helpful
How do I record or change a recorded message on the Panasonic KX-T7730?
A Panasonic 7730 phone operates on 18 different Panasonic Key Systems. There are 5 or so different ways to record a message...which one is yours?
The 7730 was first delivered with the TA-824 system. It has the ability for announcements via DISA, which was built in to the USA versions of the TA. It's recorded or changed via the master phone and PROGRAM 911.
A Panasonic TVA or TVS voice mail system does auto attendant functions. It can have both company greetings and custom service messages. Those are changed via mailbox 998, the message manager's box.
Last, the newer system also have "bulit-in" voice mail boxes. Those greetings are recorded by 722xx commands.
Carl
How do i setup my N73 voicemail
sir the voice mail box is a network service to which you may need to subscribe .for more information ,contact your service provider .to call your voice mail box ,press and hold 1 .........to edit your voice mail box number ,select menu >messaging >voice messages >voice mail box select the following settings to setup the voice mail
Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
ANSWERING MACHINE WON'T RECORD MESSAGES
The answering machine is most likely referring to the other mail boxes.
if a caller presses 1 or 2 they record in the other mail boxes.On the machine you will see an envelope with a 1 or a 2 next to the envelope.
Press and hold one of these mail boxes and when the messages are played press del to delete each message as it plays. Do this for each mail box.
Have this answering machine and have experienced this problem.
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
