Question about Frigidaire GLTF2940ES Front Load Washer
Washer wont spin
Have tried to get the washer to spin with load and without,no success. have lost owners manual so I do not know how to obtain diagnostic codes. I need to know if the door latch or the sensor is the problem. My model is LTF 2940 ES3 Man. date 07/06.
    President:
  • 1,776 Answers
If the unit will pump, but not spin, check out the following:
* Door latch switch- inside the washer main housing near the door frame. Check switch with an ohm meter to determine if it is good or bad.
* Belts
* The drive motor.
*The spin bearing or basket drive may be seized.
The most likely problem is the door switch. Hope this helped. Good luck.
Posted on Jul 16, 2009
    New Friend:
Did you just wash or a few loads ago wash an area rug or something with a lot of debris? If so, there is a filter just before the pump. You will see a rubber hose/housing for the filter. Take off the hose clamps and clean out the filter and put all back together. The hose clamps are a bit of a pain to get off and on but should work perfect after that.
Posted on Jan 07, 2013
Maytag Performa washer will not spin
Typically when the washing machines wont spin it's off the belt. I havent done this myself, I usually have a technician come out to take care of it.
Apr 16, 2013 | Maytag Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Need a owners manual formvwc300v so i can know the right way to take it apart to make repairs
You will need to type into your search engine 'maytag centennial washer manual' and you should be presented by a number of sources from which you can either download for free or have to pay.
I hope you will be able to obtain one with the instructions you require without having to pay someone to do the repairs!
Good luck,
John C
Feb 10, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer will not spin out in rinse cycle. belt needs replacing. where can I get an owners manual for free.
go to google and type in "free owners manual for...." and put the make and model of your washer in there.
Are you sure it is the belt that is the problem? It could also be the lid switch. If the lid switch is bad the washer will act as if the lid is open and wont spin.
Jun 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Looking for a Kenmore washer manual
The following link explains step-by-step how to replace the lid switch on a Kenmore Top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple repair. If you have any questions, or need additional assistance, please let me know.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Frigidaire (gallery series) err problem
ck to see that a control lock light is not illuminated, as far as fisher and paykel pressure swithc is part of motor controller under main console. removing screws behind console allows you access and from ther i would remove clear plastic tubing from right side of control and blow down the line (sometimes detergent will block other end not allowing proper readings)
Feb 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
252 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
