Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
My raypak heater is not working I have power but the screen is showing an error message SNS. What do I look for what sensor is not working.
    Scholar:
  • 91 Answers
Here is the link for the manual for your boiler.
http://www.raypak.com/uploads/6000.59R.pdf
SNS Sensor failure, Water temp. below 36°F
or above 110°F - The water temperature sensor has failed or a wire is broken. (page 35)
Posted on Aug 22, 2009
Display is reading sns. what does this mean?
SNS 1) SENSOR IS FAULTY
2) TEMPERATURE IS ABOVE 110°F
3) TEMPERATURE IS BELOW 36°F
It is one of the above situations
Apr 27, 2011 | Raypak 2100 Pool Heater Gas 336000 BTU'...
I get sns on my heater
SNS on Raypak heaters means the following:
1. Water temp is below 36 degrees F, or above 110 degrees F.
2. The sensor contains 2 thermistors. If they are more than 2 degrees aparts, an SNS failure will occur. Replace sensor.
3. Loose or corroded connection at P1 on the main CPU board (right behind the LCD screen)
4. If the sensor is not mounted ALL THE WAY into the JACO fitting (on top of the header) it will give a false reading.
It is more likely than not, that you need to replace the temperature sensor. Part number 009577F.
Jan 26, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
SNS appears on digital screen
This indicates the the 2 installed temp sensors are having a reading the is more than 2 degrees in difference. It is either a failed sensor, or one of the sensors is not fit snuggly into the header.
To test a sensor, turn your multimeter on OHMS or RESISTANCE and connect probes to each wire. at 80 degrees, the sensor should read 93 OHMS. At 70 degrees it should read 118 OHMS
at 60 degrees it should read 153 OHMS
Sep 05, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater displays SNS - sensor failure. what do i do?
sns occurs when sensor reads temps under 36 degrees or above 110 degrees. check temp of of water to verify.....may need a new water sensor
May 30, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
What does SMS on digital screen mean?
I believe the code is SNS which is sensor failure. It thinks your pool water is either above 110 degrees F or below 36 degrees F. Post the exact model/serial and will assist you further. The sensor is not expensive and somewhat easy to change if you are mechanically inclined. If not, I would strongly advise you to call your local mechanical contractor to service this boiler and it does not have to be a pool company, it can be your furnace contractor. Or let me know where you are located and I can recommend someone from that area.
Thanks
Richard
May 24, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
1,235 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
