Question about Homelite Mighty Lite Lawn Trimmer
Have gas rimmer
Have gas Trimmer "yard machines by MTD how do I get the spool off? Then I need to refil it!
  • Eugene Rounds May 11, 2010
    Please post the model number so we can find a breakdown on your unit.
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
I am trying to replace the head on my TB575EC trimmer but can't remove the black inner spool. Any suggestions?
Unscrew the head's center bump-knob counterclockwise with your fingers. Pull the bump knob off and take the spool cover off the head. Slide out the spool and any remaining cutting line. Lift out the spring underneath the spool. Take out the slide washer. Unscrew the arbor bolt either clockwise or counterclockwise, depending on model, in the center of the trimmer head using the wrench. Take the entire head off the end of the shaft.
Sep 03, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do u put on replacement spool???
This sounds like a trimmer question and was categorized wrong, if so most rimmers simply unscrew @ the bottom of the head and then you can access the spool dolly @ which time you wind the string in the direction of the arrow. Make sure to follow manufacturers recommendation on thread size. Also make sure you replace the spring as you took it off
Jul 12, 2011 | Garden
OUR CHURCH HAS AN 18" YARD MACHINE STRING TRIMMER BY MTD. MODEL NUMBER 25A-203L129. NO ONE KNOWS WHERE THE MANUEL IS AND WE NEED TO ADD CUTTING STRING. HOW DO WE DO THIS? 5.0 TECUMSEH ENGINE. THANKS MONTE
The trimmer line is pretty easy to attach. The trimmer line comes in pre-cut lengths, and is threaded in two places through loops on the spindle. (Two pre-cut trimmer lines are needed.)
Oct 11, 2010 | Mtd Garden
Rewind gas trimmer wire?
not hard i suggest if its your first time doing this take it to your local lawnmower shop buy a new $8 spool from them they will be glad to showyou how to replace it then next time you can doo it yourself? the new spools already preload the string so you can see which way it loads ussually clockwise
Aug 26, 2009 | Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr...
I am trying to rethread my spool Pam
manual can be found here
http://lawnandgarden.owneriq.net/manuals/mfg/yardman/ym137.html
refer to page 11
Jul 16, 2009 | Mtd Yard Man: Trimmer Ym137 Electric 5.5...
Homelite Mighty Lite Lawn Trimmer  Logo
47 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
