Question about DE-1730 Radar Detector
It goes off and then comes on and then it goes off and comes on again making the beeping noise when it comes on? not sure if it is a problem with the cord or the radar detector itself.
Mine was doing this as well. I replaced the power cord with a new one that had a plug that fit tighter in the hole in the side of the Whistler. I think that hole in the main unit gets sloppy ( actually the contacts in the hole ) Take it apart and bend in the contacts or try a SLIGHTLY larger plug.
Posted on Dec 17, 2011
    Sergeant:
  • Whistler Expert
  • 347 Answers
Could be a bad power cord. Does the unit act the same in a different vehicle?
Posted on Jan 07, 2010
2002 suzuki xl7 makes beeping noise under the dash when applying the brakes
Top up the brake fluid and make sure the brake stop lights are all working.
Feb 03, 2018 | 2002 Suzuki XL-7
Wierd beeping noise
bad seatbelt connection
Feb 05, 2018 | 1999 Dodge Caravan
Under the glove compartment is a beeping noise?
what is the make and model and year ?
Dec 28, 2012 | Cars & Trucks
My Jetta beeps while i drive.
I HAVE THE EXACT SAME PROBLEM! DID YOU FIX IT?
Oct 17, 2012 | 2000 Volkswagen Jetta TDI
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Hp Pavilion XT963 four beep startup and nothing
Since iam not sure about the beep noise that u get....becos there are different pattern for it.
so iam pasting this link and let me knw the pattern plz..
http://www.computerhope.com/beep.htm
or else it could be the power supply which is not placed in properly try unplug and placing it back again.
or let me knw the exact noise that u get is it a beep noise or clunking sound or very, quiet jet taking or Noisy fans.
Thank you.
Oct 01, 2008 | Computers & Internet
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
the error you are describing is a communication problem between the display module and the motor control module. unfortunately there is no test to determine which it is. most common is the motor control or RPS (rotor position sensor)
part# 425221P
Jan 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Nov 28, 2007 | Plantronics CS70 Wireless Headset
DE-1730 Radar Detector Logo
83 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
