Question about Acer AL2216WBD LCD Monitor
Lenovo notebook connected to Acer LCD - Aspec off and blocky
I have a Lenovo notebook that I have connected to my Acer LCD AL2216W monitor. It used to work fine, but now the image on the Acer is only the left 2/3 of the screen and the resolution si messed up so that I cannot read the screen. Letters appear compressed and blocky.
I have used the notebook with other monitors without a problem and I have used the Acer with other computers - also without a problem.
  • 1,511 Answers
Please change the refresh rate of your monitor and it will solve your problem
right click on your desktop and click properties
click on settings and then advanced
you will see something like this
now from this drop down list please change the refresh to 60Hz first and apply
if not good then try to increase the refresh rate
Thnx and i hope this solves your problem
Please rate this solution...Thnx
Posted on Jul 16, 2009
  • 64 Answers
I would probably try changing the resolution to the default settings and just start over. Try to make sure the output is set to go to notebook + Monitor as well, because that will give you full screen view on both screens instead of looking like you dragged a browser halfway to the other. If you need me to go further in depth please let me know.
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
I have acer lcd al2216w on the lcd there is a green line comes between my screen it cant be remove i dont not how he comes please tel me what i do change a new lcd or what it can repairable or not
Hi there reinstall the display driver & then give a look. If you face same problem then its may problem with your display driver or in the monitor.
Jan 18, 2011 | Acer AL2216W LCD Monitor
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
Wrong background color
Right click anywhere on your desktop.Make sure all programs are closed.Select properties,then select desktop.From here you can change it to anything you like.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Same problem, acer sucks imo
I think I may have fixed it but I haven't rebooted my computer yet. I uninstalled the latest ATI driver version 9.3 and then installed an older driver version 7.3. Monitor now turns on and off and gets signal every time so far. I'll post back if it the problem comes back after I reboot.
Apr 08, 2009 | Acer AL1916W 19" LCD Monitor
HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER AL2216W.
remove the hinge cover, then remove the six screws you see there. Then the base slides out.
Feb 10, 2009 | Acer AL2216W LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Acer AL2216WBD LCD Monitor Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
