Indicates evaporator fan problem. I ordered a replacement motor, but am searching for installation directions. Is the panel behind the icemaker or behind the lower freezer section?
ANSWER Hello D. W. The error code that you are getting indicates a Evaporator fan 241509402 failure. You want to check the wiring at the fan motor and at the control board. Check for 12vdc to fan between red and brown wires. Check for variant voltage (depending on high or low speed) between yellow and brown. If it checks ok then replace the Evaporator fan. If error code still exists then replace main control board 5303918514. You can test this with a multi-meter TJMA-DMT3. Here is a link on how to use a multi-meter. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Hi daneilb101 - Typically error code SY EF indicates that the refrigerator has detected an evaporator fan circuit failure. Contact a professional to move forward accurately. The wiring between the main control board and evaporator fan will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
