I know that the heater element might be gone but I wanted to know how to check it out i.e. is there a video ?I know that the heater element might be gone but I wanted to know how to check it out i.e. is there a video ?
You can't post conmments that contain an email address.
Many different scenarios that could cause it not to heat. Heating element, thermostats, breaker tripped, clogged vent, timer, motor, and maybe a few other things depending on design. Probably should get a service person out.
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
1. remove top plastic panel (retaining screws are at back) 2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge) 3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too). 4. Repeat for left side. 5. push the back and front halves of the cabinet away from each other 6. slide the new belt around the front of the drum 7. reassemble 8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
